All,
Do the rear springs have a top and a bottom to them?? The reason I ask is that there appears to be a slight difference to the spring ends?
Also the springs appeared to be colour coded, or doesn't this mean anything?
I've just painted the springs, removed the rust! As I was doing this I removed the black plastic sleeve from both springs and now I don't know which end I should refit it to?:bang:
Also... are Sporting springs much different to 'S' springs?? Will the car, (its all going onto an 'S') - will the car noticeably sit lower at the back end - or is it just that these springs are stiffer??
Jon
Jon
