Old 27-08-2011   #1
compression?
i did a compression today and i was getting 2bar (25psi) on all cylinders. Is there a correct pressure? thanks
tommol is offline Reply With Quote Quote
Old 27-08-2011   #2
In my little red shed
Icestorm's Avatar
Icestorm has donated!
Re: compression?
Hi
I've had a look through my haynes manual and can't find a recommended pressure for the compression test but it does say "all cylinders should produce very similar pressures; any excessive difference indicates the existence of a fault"
Icestorm is offline Reply With Quote Quote
Old 27-08-2011   #3
Trader Rating: 5
fingers99 has donated!
Re: compression?
Something is wrong, but more probably in the way you did it. You should do it with the throttle fully open, engine up to temperature, and the TDC sensor disconnected.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 27-08-2011   #4
Re: compression?
Should be up around 160psi.
Alfa 155 2.0 TS 16v & FIAT Seicento Abarth
Bazza155 is offline Reply With Quote Quote
Old 27-08-2011   #5
Re: compression?
i have tryed it with the throttle open and its around 50psi now? where is the TDC sensor? am i doing it right with taking all the plugs out? Thanks
Old 27-08-2011   #6
Sh*tbox Club
Trader Rating: 2
Todger182 has donated!
Re: compression?
You are cranking it over for atleast 5 seconds aren't you?
X
Todger182 is offline Reply With Quote Quote
Old 27-08-2011   #7
Trader Rating: 5
Re: compression?
It does seem very low. Follow the lead from the TDC sensor back upwards -- there's usually a connector on the plate below the TB.
Can you let us know why you're doing a compression test?
This is a good guide.
M12 fund 20
Old 27-08-2011   #8
Re: compression?
Quote Originally Posted by fingers99 View Post
why im doing it is because the headgasket went but we never got the head skimmed when we fixing it and there is still a little bit of white smoke still coming out of the exhaust on start up and idles high on start up but then goes normal Thanks
Old 27-08-2011   #9
Trader Rating: 5
Re: compression?
Puzzling. Usually the HG will go between 2 cylinders, rather than all 4!
I'd be inclined to crank it for at least 10 seconds, leave all the plugs in apart from the one with the guage in.
But something is wrong with the readings -- if the compression as really 2 bar I'd not expect the engine to run.
M12 fund 20
(T) No compression stilojam Stilo 2 11-02-2010 18:34
(G) compression motormadness Punto (Mk2/2b) 1 06-02-2010 22:06
(T) Compression itrepus 124 Spider (Classic) 2 03-07-2008 02:52
(T) compression river Marea 3 16-02-2006 19:51
