Old 04-01-2011   #1
borelandbarnes has donated!
Rear Wiper and Heated Rear Window simultaneous, intermittent failure.
I am having an intermittent problem on my 2002 Sporting Seicento. Both the rear wiper and HRW stop working at the same time (then start working again at the same time). The contact block on the boot looks OK. The fuses are obviously OK. Could it be an earth problem? If so is it the earth at the rear of the car on the exhaust side? Any other ideas? Many thanks
borelandbarnes is offline Reply With Quote Quote
Old 04-01-2011   #2
Re: Rear Wiper and Heated Rear Window simultaneous, intermittent failure.
sounds like it could well be an earth issue.. clean up the earth you mentioned and wack it back on.. go from there
Thanks borelandbarnes thanked for this post
the invader: http://www.fiatforum.com/members-motors-non-fiat/270284-its-ford.html#post2762950
Quote Originally Posted by The Unknown View Post
IV Seen Bigger
Come to the darkside. We have cookies !
dronenrs is offline Reply With Quote Quote
Old 04-01-2011   #3
sounds like the block tbh. when it happens open the boot and close it again, if it fixes it id say clean up the blocks.
clock34 is offline Reply With Quote Quote
Old 04-01-2011   #4
Think there is a common earth between the car and the tailgate...
My car needs copper grease on the contacts.
Does the high level stop light fail as well?
Noel
standard Sei Sporting except for
colour matched ice scraper, screw driver,
& steering wheel lock i.e yellow car
spare alternator belt, clutch cable & bulb set, 2x overalls
Pep0 is offline Reply With Quote Quote
Old 04-01-2011   #5
High level stop light is OK, still an earth problem do you think?
Old 06-01-2011   #6
Quote Originally Posted by borelandbarnes View Post
Dont no. I'd have to check the tailgate wiring with a multi meter on resistance, I recall from last time I had problems it (the wiring) was strange, so might still be earth. All my problems were the tail gate contects.
Try folding the seats and look at voltage on wiring with combinations of wiper and heater on and off, from inside the auto.
Sorry
Noel
Old 06-01-2011   #7
Trader Rating: 2
I had this for a short while - turned out the tailgate wasn't shutting properly so the contacts were very poor.
09 Abarth 500 first 200 launch edition
jimbro1000 is offline Reply With Quote Quote
Old 07-01-2011   #8
Job sorted ............ it was the contact block (the strip of 4) on the body. Turned out that it had melted inside the "2 pin" conector at the back. Got one from scrapie (DA Autos, Dumfries ...... they have 3 sportings in "stock" and mail order 2nd hand parts world wide!!) for 5 they gave me all 4 blocks. Thanks to all for the help
(T) Rear wiper motor and reat heated window andypuk Punto (Mk2/2b) 2 27-02-2010 16:33
(T) Heated rear window and wiper stopped but have changed fuses pippa2 Bravo / Brava 3 14-01-2009 17:35
(T) heated rear window david williams t595 Punto (Mk1) 0 12-12-2008 17:12
(T) Rear Heated Window barachello2000 Bravo / Brava 4 04-01-2005 00:08
(T) Rear Wiper/Heated Window rick_p Cinquecento / Seicento 2 02-11-2004 11:57
