Sporty_5_Seicento
Member
The car is a Seicento Sporting SPI 2000 (W reg) with 68,000 miles. Spent most of its life fairly modifed.
I had a noise start about a week ago which appeared to be from the gearbox/clutch area at the front of the car. The noise was there whether you were stationary or moving! Its a constant whirring/graunching which appears to increase with engine revs slightly. The noise did not change when the clutch was depressed. Changed into all gears without too much effort.
Checked the gearbox oil and it was at the correct level.
We removed the gearbox and the clutch, thrust bearing and everything seems fine and free.
When turning the gearbox main layshaft (the one that the thrust bearing sits on) the gearbox seems to make a whirring noise. Is this normal? There is no play or anything on this layshaft!
Any help would be much appreciated.
Regards
Matt
Regards
Matt
