pretty impressive stuff!
any chance you can do a proper members motors thread in the MM section?
opens up your car to other members and you can collate all the info into one reference thread
(thats in addition to threads in the cento section though!)
Thankyou, yes i will do a members motors thread, ive been away from fiat forum for a while but i try and get on every so often so ill get round to it asap
Indeed impressive stuff!
I don't believe you have those seicento seats in!. I think they just sit way too high!
Hmmm see the camber bolts, which car did you order them for ? As mine never got those plates you got ...
Ming
I always liked the look of the sie seats
but yes they are tall......going soon for buckets! heheee
How much was the rear anti roll bar setup.
around 125quid i think
All i ever use. Payen seem to be the best everyday gaskets.
Must be the understatement of the decade! Well done!
LSD must be a must. If you switch to an aftermarket ECU, most will do boost limiting in lower gears which might make the car more controlable (and save the gearbag). Means going to MPI, though.......
Rods are said to only be safe for a little more than 140bhp...........
Do I still get my test drive?
Thankyou, the car runs MPI now (basicaly the full 75 engine) so it would be easy and better to go down that route anyway. Ill pop up some time for you to see what you think.
The trick seems to be to combine a modern, all singing, all dancing ECU with a boost controller and something which can read which gear the car is in: you end up with a fairly crude version of ESP. Dave Walker is someone who it's worthwhile talking to about this.
Alternatively, it might just be possible to snag the ECU from a 500 along with the relevant sensors and reprogram the EPS from that. I know the 500 ECU can be programmed, not sure about the 500 Abarth one. Oldschool will know.
I'm always impressed by the EPS on the niece's Bini Cooper S Works, at least in the dry: she reports having it on the wrong side of the road in the wet.
Mind you, the Jason mobile would eat a Cooper S on power to weight alone.
The first car i came across after the setup was mondeo ST220 which tried to over take from around 35mph, right up past 100 and i was still pulling away, works out at around 220bhp per ton with the interior stripped out as it is.
Anyway, the latest update.....ive today finished and setup my Aqumist water/methonal injection!
The kit runs the smallest jet (240cc/hr) at 9 bar pressure and takes a feed off pure water from a tank in the rear off the car (no methonal yet).
It is set to come in at 10psi, inlet temps have dropped massilvley on just water alone!, the pipes are cold to touch after a hard run like a cold can from the fridge, and the kit is working insainly well, holding the car in fourth gear at full boost and then flicking the switch to acctivate the water injection results in an instant kick and an increase in power right upto the the max revs, The kit seems to have a slightly negative effect on the power at 10psi when the inlet temps seem to be very low to start with but at 15psi the increase was suprizing to say that i didnt fit the kit for power gains, the tyres where not pleased after the trip home trying the kit for the first time and its brought on torque steer in third that makes things a little scary :devil:
I feel alot better knowing the charge temps, cylinder temps and EGTs are far far lower keeping the engine safer from DET, now im thinking its wize to turn down the boost a little to bring the power back down, power with the kit and my meth intercooler spray (which lowers temps upto 5 degrees alone) is estimated to be 165bhp/153lb.sf at least! Guys using these GT17 turbos on turbo minis and Nobles Motorsport estimated that a large cooler or water injection could release another 10bhp from the more than capable turbo, it has to be somehwere around that area for the increase in surge when activating the switch
.........hard to turn down the boost
but its better than holding my conrods and pistons at the side off the road somewhere i surpose
Thankyou
jason
