ralphtown
OK,Heres an update on my yellow peril cento.
After replacing lots of sensors and installing my own water temp gauge and other little detail jobs,the car failed its MOT on HC levels.
Now,thanks to the advice given on this forum and I really mean that,there,s been some cracking advice given here,I have checked rubber pipes,which are all OK.
I,ve checked to see if the cam belt has jumped,which also turned out to be OK.
Our issue is with the cold start device fitted to the side of the throttle body.
This is what I did.
I disconnected the battery.
Removed the electical plug from the device and removed the 2 torx type fittings holding it on.
I then sprayed a load of carby cleaner down the throttle body and into the hole left by the cold start device.
I checked the old one against the new one and the old one was at least 1/4 inch further out than the new one.
The original factory part is all black plastic,where the new one has a metal end to it.
I fitted the new component and fired the car up.
It ran fine but at a really high idle,like 1200/1500 rpm.
So,I killed the engine,then suddenly realised that I,d read on here a procedure for installing this part.
Once I,d put some slack into the throttle cable I fired up the engine but it started dong that BROOM...BROOOM...Broom.
Revving itself as if it was alive.
SO...(finally).
What did I do wrong?
I really want the new part on but after cleaning the old unit,it does tick over a little less lumpy.
Please supply me with the correct installation procedure and checks I can carry out to have a successful conclusion.
I,m so close with this car but every step forwards has me taking 2 backwards.
Thanks guys.
RALPH
This is what I did.
SO...(finally).
Thanks guys.
RALPH
