FIAT Auto Specialist Team
Old 11-02-2010   #1
My car died while driving
Can u help,i was driving my car and it just died on me, i took the fuel line of carb and got my mrs to turn it over, fuel came out of the carb but none come up from pipe is it the fuel pump if it it were is it, thanx
HERRON is offline Reply With Quote Quote
Old 11-02-2010   #2
back in black!!!!!!
blackmagic11's Avatar
Trader Rating: 1
blackmagic11 has donated!
Re: My car died while driving
lift up rear passenger seat and remove 4 pozi-head screws, then the diamond shaped plate to better see and hear fuel pump better
blackmagic11 is offline Reply With Quote Quote
Old 11-02-2010   #3
Trader Rating: 3
whitz has donated!
Bomber Bob Champion
carb
as its a 899cc its more then likely fuel injection
as you were driving did anything happen? such as lights going dim aux belt squeal if so check the alternator is giving a good charge out or if the belt is missing
if its cheap its generally cheap for a reason
whitz is offline Reply With Quote Quote
Old 11-02-2010   #4
arc
this is where i stand
arc has donated!
as said, it wont be a carb - it's an injection system (assuming you are in the UK)
which pipe did you pull off to check fuel flow? You don't need to, just remove the airbox and turn the car over - you'll see fuel pool on the butterfly.
if you pull the fuel supply hose off, when you turn the ignition on you'll get fuel spray out at around 1.2bar.
when you turn the ignition on, you should hear the pump prime for 2 seconds (it is, as stated, below the rear seats 8mm nuts, not pozi screws mind).
did you hit a bump before it died? could've tripped the fuel cutout. this is located right in the middle of the centre console, but bolted to the bulk head. has a big button on it.
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 11-02-2010   #5
Quote Originally Posted by blackmagic11 View Post
ive had a look under seet and there is no screws, should pet come out of the pipe near the bat on the left at back,or does it pump out of carb
Old 11-02-2010   #6
arc
arc has donated!
tell us what car you have for a start, and stop pulling hoses off it - it's not a carb, you'll be spraying fuel all over the place. The pump could be fine and you're just pulling hoses off the evap/charcoal canister.
Old 11-02-2010   #7
Trader Rating: 3
whitz has donated!
Bomber Bob Champion
its 899 just had a quick peek at his other threads
Old 11-02-2010   #8
its a 899cc Cinquecent L REG
Old 11-02-2010   #9
back in black!!!!!!
Trader Rating: 1
i was close
Old 12-02-2010   #10
I was just driving down rhyl prom the red injecter light come on and the car spluttered like mad i puled over and it died,i tryd to start it it was firing but then stopped
THE PIPE I TOOK OFF WAS ON THE LEFT TRACING IT TO BACK OF CAR, NO FUEL CAME OUT OF IT,,BUT FUEL CAME OUT OF WERE THE I TOOK THE PIPE OFF, AND YES I CAN HEAR IT PRIMING FOR ABOUT 2 SECS
Old 12-02-2010   #11
Trader Rating: 3
whitz has donated!
Bomber Bob Champion
daft question but you do have petrol in it ?
Old 12-02-2010   #12
Lol its half full, just had a look fot the button underneath all i can see is , its about the size of a coke can with the fuel pipes either end but no button
Old 12-02-2010   #13
back in black!!!!!!
Trader Rating: 1
did something similar on my mrs punto 75, turned out a coil pack had gone.
completely flooded the engine with petrol twice trying to find the problem.
check if you have spark
check the air inlet system
check if their is fuel being sent into the cylinders(remove plugs,move plug leads well out of the way, get a second person to turn the engine over and stay to the side otherwise you will be very clean and high afterwards)
Old 12-02-2010   #14
back in black!!!!!!
Trader Rating: 1
and if you are not sure as to what you are doing, get someone with you who does otherwise it will cost alot more when it goes bang
Old 12-02-2010   #15
Ok but should fuel come out of the pipe, cuz its comming out of carb when pipe is off
(G) Fiat just died while i was driving! crozell 500 (Classic) 2 13-05-2009 02:13
(T) car had died on me suzukirider_2006 Punto (Mk2/2b) 20 03-11-2007 16:00
(T) help!my car died today need some advise please finnis39 Bravo / Brava 4 04-06-2007 11:46
(T) My GP 1.4 Sporting died whilst driving in traffic! koksy Grande Punto 19 18-05-2007 19:03
(T) Car just Died 16vmini Bravo / Brava 34 29-11-2004 12:58
