Old 31-10-2009   #1
Trader Rating: 1
Bilstein Shocks OE Spec
Can anyone tell me how good these are compared to like apex or pi shocks.
As im thinking about puttin The bilstein oe spec shocks on my cinq instead if the apex stuff with a 60mm lowering spring.
Absoluteleft is offline Reply With Quote Quote
Old 31-10-2009   #2
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: Bilstein Shocks OE Spec
If they are black and OE spec they will not suit your lowering springs.
SPD
Old 31-10-2009   #3
Sh*tbox Club
Trader Rating: 2
Todger182 has donated!
My APEX kit is very good, it doesn't like bumps too much but it is very good.
Personally though I would save your pennies and go for either AVO coilovers or FK coilovers. FK's aren't that much more expensive than the APEX kit.
Don't forget to consult with your insurance provider to find increases in your policy.
Todger182 is offline Reply With Quote Quote
Old 01-11-2009   #4
beecon has donated!
KYB make OEM spec struts for the cento. In fact I think they made the actual OEM struts fitted to new centos. They're twenty something quid each IIRC.
I paid a little bit more and went for the KYB Ultra SRs. A pair of fronts came to about 75 a few months ago but the backs will be cheaper. I'm no expert on suspension, but the car certainly does feel more 'planted' in corners with them fitted. They're designed for use with lowering springs and are damped to reflect this.
They look so similar to stock struts that you can probably get away with not declaring them to insurance. FTR I have declared my suspension mods. Not that it matters anyway as I'm 200 miles away from my car and my insurance ran out yesterday...
Camskill has good stock of KYB parts. Unsurprisingly the cento struts were out of stock but delivery still only took 2 or 3 days.
My beloved MPI Seicento is now on eBay:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=261364494270
beecon is offline Reply With Quote Quote
Old 01-11-2009   #5
Trader Rating: 5
fingers99 has donated!
If they're not shortened, they're very unlikely to work with a 60mm drop. With that drop, only a kit is likely to work (but there are shortened shocks out there -- Spax for example).
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 01-11-2009   #6
beecon has donated!
Agreed - I've just read that mine are designed for drops of up to 40mm.
You need shortened shocks.
Old 01-11-2009   #7
Autotest Special
rallycinq's Avatar
Trader Rating: 1
-60mm is track spec, its not sensible for road use in the UK.
So, track spec dampers needed.
SPD
Old 01-11-2009   #8
Trader Rating: 1
Thanks guys great help
(S) Bilstein Shocks minimad99 Stilo 5 16-10-2006 23:57
(T) bilstein springs and shocks the beasto Cinquecento / Seicento 4 28-05-2006 16:48
(T) Bilstein front shocks - howto? woj Cinquecento / Seicento 31 03-02-2006 20:01
(T) Bilstein Suspension gaz.d Cinquecento / Seicento 21 04-12-2005 16:01
