Thread Tools
Old 29-09-2009   #1
Sticking Gears on Seicento
My manual Seicento 899 has recently developed a fault where the car has been increasingly hard to get into gear. Reverse and 1st are the worst and when changing gears the higher the revs the harder it becomes.
Last night it became much worse and wont go into first at all and is extremely difficult in the other gears.
Does anyone have any ideas? The clutch seemed fine before with no judder or slip. Would it be anything to do with low clutch fluid/gearbox oil?
Many Thanks
hust is offline Reply With Quote Quote
Old 29-09-2009   #2
Sh*tbox Club
sei16v's Avatar
Trader Rating: 1
sei16v has donated!
Re: Sticking Gears on Seicento
Could be oil, but i had this same problem with a sporting and ended up replacing the gearbox
WANTED - SEICENTO ABARTH WHEELS - PM ME WAITING
Jim fixed it for me!!!... to milk a cow blindfolded
sei16v is offline Reply With Quote Quote
Old 29-09-2009   #3
Mmmm...... was hoping that wouldn't be the case. I've read in another thread that the clutch cable can stretch so the clutch doesn't fully disengage properly.
Any thoughts on that?
Old 29-09-2009   #4
Yes adjust the clutch, but it is likely to be on way out, you are receiving the warnings... via the gear stick.
The box is probably ok but check the oil level in the box before driving anywhere. Inspect the inner drive shaft gaiters for any oil residue. Drive way ditto.
Noel
standard Sei Sporting except for
colour matched ice scraper, screw driver,
& steering wheel lock i.e yellow car
spare alternator belt, clutch cable & bulb set, 2x overalls
Pep0 is offline Reply With Quote Quote
Old 29-09-2009   #5
Thanks i'll try that.
I'll start saving for the new clutch when I'll need it!
Thanks again
Old 29-09-2009   #6
Trader Rating: 5
fingers99 has donated!
Clutch adjustment. It's a cable clutch, so will require adjustment throughout its life (hydraulic clutches auto adjust until they die).
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 29-09-2009   #7
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
After adjusting the clutch cable, do check your gear oil level, and make sure you do it at least once a month.
SPD
Thread Tools
(T) sticking brakes!!!! need help hottastilo Stilo 4 12-10-2008 12:17
(T) rev sticking assassin Bravo / Brava 5 11-02-2008 12:45
(G) Help! my seicento is struggling in gears Gemsy Cinquecento / Seicento 2 04-01-2008 20:40
(T) Sticky Seicento gears getcarter Cinquecento / Seicento 9 13-04-2006 00:00
Please help - Car sounds strange and something is sticking.... (Seicento) helpmark Lets Talk FIAT 3 02-01-2005 21:38
