allanhelen I Need Beer Parked in the garage Written a guide Joined Mar 21, 2006 Messages 3,162 Points 589 Location Looking at an empty Glass Jun 9, 2009 #1 Does anyone know the capacity of the radiator for an SPI Cento? I know the cooling system total volume is ~4L but how much does just the rad hold?
Jules Sei New member Joined May 20, 2009 Messages 48 Points 10 Jun 9, 2009 #2 allanhelen said: Does anyone know the capacity of the radiator for an SPI Cento? I know the cooling system total volume is ~4L but how much does just the rad hold? Click to expand... I would guess as near to two litres as makes no odds. Based on 50% flowing through the rad and 50% in the engine/heater matrix once the thermostat has opened. (the no odds would be what is in the expansion tank at a given moment.) This would give optimum cooling. Cheers Jules
P Pep0 Established member Joined Jan 9, 2009 Messages 3,254 Points 424 Location UK Jun 9, 2009 #3 not to mention pipes and heater matrix, but the capacity might be that large, only one way to check... Noel
OP OP allanhelen I Need Beer Parked in the garage Written a guide Joined Mar 21, 2006 Messages 3,162 Points 589 Location Looking at an empty Glass Jun 9, 2009 #4 I meant to measure it before it went onto the car but forgot (BTW this one is not fitted to a cento)
Italian Coke Can Member Joined Nov 20, 2005 Messages 487 Points 103 Jun 9, 2009 #5 500ml? The end caps would hold ~200 ml each and the channels maybe ~100ml.
fingers99 Patron member Parked in the garage Written a guide Joined Mar 20, 2006 Messages 27,743 Points 4,560 Location Liverpool Jun 9, 2009 #6 I'll try and measure it for you Thursday -- I've one off a car. But remind me tomorrow night.
OP OP allanhelen I Need Beer Parked in the garage Written a guide Joined Mar 21, 2006 Messages 3,162 Points 589 Location Looking at an empty Glass Jun 10, 2009 #7 fingers99 said: I'll try and measure it for you Thursday -- I've one off a car. But remind me tomorrow night. Click to expand... Cheers John that would be great if you can (it is for the charge cooler on my MX-5 i need a really weak antifreeze mix with water wetter in there so need an idea of the volume so I can work out the ratio I'm just running plain water at the min)
fingers99 Patron member Parked in the garage Written a guide Joined Mar 20, 2006 Messages 27,743 Points 4,560 Location Liverpool Jun 11, 2009 #8 And the answer, measured with the garage's reserve kettle, is 0.7litres.
OP OP allanhelen I Need Beer Parked in the garage Written a guide Joined Mar 21, 2006 Messages 3,162 Points 589 Location Looking at an empty Glass Jun 11, 2009 #9 Thanks, hope i didn't deprive you of a cuppa
