Just for you mate .... all the effort digging the thing out and taking the pics!
Pic of the manifold, the temp sensor is on the right (slighly blue)
Anyway, here is close up of where the temp sensor is :
Here is the brake servo connection on the Uno inlet
Here is the brake servo + map pipe connection on the cinq inlet
Notice they are just screw on, so i think it should just unscrew out. Not sure i would do it without damaging it, will consult rallycinq
The hole where the TB sits on is only 38mm, so you really need it to be 40 if you have the 40mm Tb fitted.
Also the inlet port is only 19mm wide, you need to open that up to the 23mm. Just match it to the gasket it should fine. I have matched up the uno gasket and cinq gasket, they are exactly the same.
Ming
