FIAT Auto Specialist Team
Thread Tools
Old 15-04-2009   #1
Trader Rating: 3
gazzaman2k has donated!
turbo gaskget
seeing as vauxhall dont make a manifold gasket for the astra garret t15 turbo, i ws wondering is i use some of that gasket card that you buy in sheets and use some of that if thatll do the job or just burn up?
Project Seicento
gazzaman2k is offline Reply With Quote Quote
Old 15-04-2009   #2
Trader Rating: 1
craigb244 has donated!
spankthemonkey Champion
Re: turbo gaskget
just use fire gum... thats what its for... any normal gasket will just burn up.
1997 - White - Cinquecento - PPC featured High boost 16v Turbo
2010 - White - Punto evo GP
craigb244 is offline Reply With Quote Quote
Old 15-04-2009   #3
Trader Rating: 5
fingers99 has donated!
Re: turbo gaskget
Get the surfaces ground flat (or DIY rubbed finish -- surface plate and valve cutting paste). Do it right and you'll not have to use any firegum, although a tiny smear is OK. Now would be a good time to address the issue of the bolts bending if you don't flat off the relevant parts of the turbo housing........
M12 fund 20
fingers99 is offline Reply With Quote Quote
Thread Tools
(G) Punto 1.8 HGT - Turbo Kit/Eaton Supercharger/ 16v Turbo Coupe Engine?? Mooks Punto (Mk2/2b) 29 11-03-2014 13:59
(T) New Member - JTD Turbo boost pipe swelling & Silicone Turbo Hose? Lee M Grande Punto 6 15-04-2009 12:39
(G) 2.8jtd turbo squeal and turbo boost light under heavy load. beekay Ducato 8 20-07-2007 23:37
various uno turbo mark 1/2 stuff (and punto, tipo, tempra, R5 turbo). christopher watson Auction Watch 1 30-07-2005 23:53
