Styling Turbo Banana Seicento Project 2
Leicester
Got bored of my last project shouldnt have done the body styling so thats being sold soon on ebay....
Heres my new beast.....
1998 Secento Sporting in broom yellow
the mods im doing are:
MK1 Uno Turbo calipers all round
Dropped 55mm on shortened shocks
briaded hoses all round
MG TF fuel pump
delocked
Keyless entry and ignition/start (no key needed to start car all going to be hidden behind dash
Custom dash with 1.5" lcd in rev counter, boost guage, rev counter, water temp and oil temp guages built into dash
Turbosmart boost controller
Tints
going to look completely standard from outside except low and tinted
engine mods.... Currently being done
Punto 75 1242cc engine
punto 85 pistons on 16v rods
fully ballanced bottom end and crank
lightened flywheel
stilo 16v clutch and flywheel
garret hybrid t15/t20 turbo with custom made exhaust manifold ceramic coated inside and out
fully ported and polished head with valve guides cut
multi staged valves
punto 75 MPI head for the larger intake valves
MG TF injectors or punto GT aint decided yet
866 CAM from punto 75
flatted engine block
43mm Tricker TB with port polished inlet manifold modified
intercooler
dump valve
running on megasquirt 2 v3
to come...
Gearbox might be getting a LSD Funds permitting once they have been made
heres few pics of it so far engine is currently being built by zak (slosei) should have for the weekend
pics of manifold to come as its currently at the engineering shop being flatted for a nice smooth mating surface then off to the ceramic coating place
few pics.....
been told to leave the out side bit, Gaz will be painting that,
nice one gaz... same set up as me :D guess youll be wanting to borrow my msq ;)
maybee.... ;) please lol well for starters to get it running lol once its done wont be for about a month yet
yeah outside will be getting wirebrushed, and pinted good n propper, look at the flatness :D its looking good (y) cheers
right i now have my engine back and done a huge thanks to Zak for doing it for me :)
now ive been told to use my copper decomp plate with this instead of a headgasket....
now the decomp plate i have is 1.5mm thick and made of solid copper.
on a standard 1108cc sporting it drops the ratio to 8.2-1
my block has been skimmed and so will the head be so both surfaces will be highly flat
i want to be running around 1bar of boost maybe more.
if i put this decomp plate on i then have even lower compression due to the punto 85 pistons and the decomp plate.
will this be ok for my turbo application?
why you gotta use that instead of a head gasket? sounds a bit dodgy. most engines that have a solid gasket like that have firerings... this where they mill a ring around the combustion chambers on the head and block and fit stainless (or other metal) rings that seal them.
you really need to work out the CR. if you run to low you wont have any power off boost. horrid to drive.
really you want as high as compression you can that it allowed for the boost you plan to use.
yep! i would fit a normal gasket to start with anyway. in fact my engine now has a used gasket lol
when i took the engine apart to fit the 16valve pistons the head gasket came off easy and had only been used for a short time.
I just thought it looked fine and saves me wasting money if the 16valve pistons of unknown history where scrap.
good luck with your new toy mate, it is a shame about your other one, after all that pain and work, but if its not to be, then i guess its not to be, it sounds like you've got some good plans lined up. I don't suppose you'd sell the exhaust off your old one would you?:chin:
Just to get the point accross, measure the CR or get someone to do it.
Burette's are not too expensive to buy. If I had one I'd lend it but sadly I don't. I know JonSpeed mini's in nuneaton sell them in their store and ebay. Maybe ring them and pick one up, not too far :)
Kristian
also a good way to see if your valve seats are doing the job.
I lapped all my mini valves in(well thought i had) went to measure the CR and half of them leaked:rolleyes:
the block has been skimmed so the pistons protrude out the block 0.3-0.4mm iirc
my mistake i thought the copper gasket was 1mm thick
dont want the pistons having contact with the head or valves,rods do stretch dont they? @high revs?
Zak:)
right not much has been done really as at the mo im wirebrusing all the rust off the block and going to spray it with high temp paint :)
got my manifold back from the machine shop after being flatted ****ing bank holiday has been aload of **** because post had stopped and none of the things i ordered come so iive had feck all to do.
few pics of my manifold are here just got to send them off for ceramic coating now in white or black not sure yet
as you can see ive grinded out most of the cross sectional bit inside had a new block welded on and tapped (no more crappy elicoils) ported it all out to more or less give it smooth flow inside the manifold :)
