Right, after hearing that I can boost the power by changing the CR, Ive been thinking:
A. Raising the CR means charge temp is going to be higher so it will inevitably preignite - but this can be solved so is no major deal.
B. The raised temperature means a higher likelyhood of melting pistons etc...
So with this in mind, whats the highest CR I could use without making engine conditions too warm? Is 11:1 too high? I suppose If I burretted the head I could actually calculate that...or, has anyone already done it?
