Thread Tools
Old 30-09-2004   #1
Question No brake Lights!
Hey
I've got a bit of a problem, my brake lights are not working, however the strip brake light in my spoiler does?
I've checked the bulbs and they have not blown and checked the fuse also, altho im prettty sure the strip brake light wouldn't work if the fuse had gone anyway?
Im stumped now? Any1 got any ideas? Any help will b much appreciated
Cheers Mike
"Yellow is Mellow"
96P Cinq Broom Yellow Full Abarth Kit K&N 57i Clifford Alarm Lowered Tinted and a Recent badger shape dent in the front
Mikey_B is offline Reply With Quote Quote
Old 30-09-2004   #2
Funny saying here
jamie86's Avatar
Trader Rating: 1
jamie86 has donated!
Re: No brake Lights!
Have u got a tester to check that any power is actually goin to the bulbs?!
Quote Originally Posted by A wise person
Mini invented the giant killer, VW started the genre, Ford & Vauxhall Desecrated it, but the Peugeot 205 GTi was undoubtedly the king of the breed.
jamie86 is offline Reply With Quote Quote
Old 30-09-2004   #3
Exclamation Re: No brake Lights!
No, if there is no power goin to them, wot then?
"Yellow is Mellow"
Old 30-09-2004   #4
I would have said the switch but the spoiler one works. If not the switch then the bulbs but they work. Very odd. Could have been a bad earth on the lighting unit but that would stop all bulbs working. It is certainly a good one. Try disconnecting your LED spoiler one to see if it is drawing too much current away from the bulbs. Doubt it but this is the only thing i can think of
MotorWorldChink is offline Reply With Quote Quote
Old 30-09-2004   #5
HP
I was only doing 80...
HP's Avatar
HP has donated!
Sounds like a loose or broken wire somewhere, if you're getting power to the 3rd brakelight it's not fuse or switch. Could be an earth problem too.
Pete.
"Make something idiot proof and someone will just go and build a better idiot".
HP is offline Reply With Quote Quote
Old 01-10-2004   #6
A couple of weeks a go both my brake lights and reverse lights stopped working which made the car unuseable so i took both back lights out and checked them to find nothing wrong replaced all the bulbs even though the others werent blown and guess what they still didnt work
The break light switch was alright so i checked the fuse box and after past experience have learned to ignore the symobols for the fuses and instead took each fuse out one by one and checked it untill i got to this brown 75 amp fuse which i replaced and my brake lights and reverse lights started to work.
go figure that one out
theres nothing like a fiat
Mincento Autospares-For Fiat and Alfa romeo spares, message via PM and ill get back to you
The younger modder is offline Reply With Quote Quote
Old 01-10-2004   #7
Thing is fuses only blow for a reason so if i were you i'd get searching before you burn some wire out. 7.5 amps is quite a lot down a little piece of wire if you have a short somewhere
Thread Tools
(T) Brake light staying on when lights on Shakey Cinquecento / Seicento 2 22-09-2004 11:50
(G) Brake Lights - How many are allowed gaz.d Cinquecento / Seicento 8 30-01-2004 19:43
(T) Brake lights sort of not working...sometimes Sando Cinquecento / Seicento 2 18-11-2003 06:47
(T) Brake Lights rebelbuttmunch Marea 3 04-11-2003 17:16
HELP! Brake Lights. MikeWhitcombe Lets Talk FIAT 5 10-07-2003 22:25
