General (another) update on my car.
arc
this is where i stand
Manchester
ok, thought i'd do another update thread. still not finished. but getting there.
257mm Vented GT brakes (thanks Peaster2k)
wheels now upgraded to 14" speedliens (thanks Brooky)
1000A / 155min deep cylce battery fitted (thanks brothers mate)
it all lights up now
LC1 is working and calibrated (hence red led near red button) and i've finally got my cd back out the head unit. :slayer:
Stuff left to do:
1> Decide on fuses needed for injectors / fuel pump.
2> check wiring to ecu/ecu ok and map it.
3> fill with oil and coolant.
4> attach handbrake cable
5> bleed brakes
6> mount catch tank and connect breather system.
got slightly worried before, walked round to the back of the car and could smell summit had got warm. panicing, i sniffed round the battery and then to the front of the car - then remembered, on first power up - the LC1 has to calibrate the heater circuit for the lambda, and thats what i could smell heating up. phew.
getting there now(y) (y) (y) looking at the list it could be done in a weekend if you can get a map from someone else(y)
Me brakes will be fitted this weekend,and the N/S driveshaft and wheel bearing did a poo on the way back from yours,so a big suspension and brakes weekend for me.i get rattles and groans from every corner of me car:rolleyes:
thanks guys. car did make me smile for first time in a while when it all powered on and lit up! w00t w00t!!
gonna get a bit done on saturday i think, but got plans this weekend already. so might be another few weeks yet!
Sunglasses at night as well? :D
aye, they're a bit bright. easy enough to fix though (y)
just need to figure out the pesky MS wiring fault :(
stunning! Very tidy. Hope you get it finished and out on the road before whats left of the summer goes
lol sweet as a nut dude dont u mean low compression high boost though :D been eagerly following progress on your car for ages good to see it getting there gives me inspiration to crack on with mine :rolleyes: when im not doing bloody engine transplants to JTD's :bang:
hi. logged in at a mates house. but no, i mean - high compression, high boost. its going to be a silly engine.. :slayer:
