Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Seicento 1108 Alternator removal and refitting<!-- google_ad_section_end -->
Without removing the engine mount
Published by Radlet6
04-03-2009
Unrated
User Rated:Unrated
Getting started
Before we start I am not going into too much detail here as many of the routines are simillar others posted.
1. Nip down to your local motorist discount shop and invest in an 8mm allen key or socket - the type with the ball end so that you can attack allen screws from angles other than 90 degrees or straight on. This is crucial to making the job easier as the bolts not only have a 16mm hex head but the 8mm socket too.
2. You can only get to the alternator by jacking up the car and removing the right front wheel and the plastic inner wheel arch covers (seems almost all the jobs I have to do involve doing this)
3. You will now see the alternator nested neatly in the top right hand corner of the gap, along with the two bolts: The bottom mounting bolt is easy to get at, it is the adjusting bolt at the top that is the pig.
Thanks wanderingbiped, webbie, Dan thanked for this post
Contents
<< <    Next Page: Removing the alternator (Page 1 of 5)    >  >>
Old 13-05-2009   #1
Re: Seicento 1108 Alternator removal and refitting
A very inventive solution to the problem.
I had just done the alternator on a Cinq sporting before I read this, I loosened the engine mount as per the manual, and it can be a ballache!
I used a jack and a piece of wood to support the engine- that was no problem, the difficult bit is the top two bolts on the engine mount are impossible to access with a socket as they are too close to the body. Removal of the expansion tank (push it to one side still connected) makes this just about possible but the smaller bolt is still really awkward to get to without a 13mm cranked ring spanner.
So there you go two methods, you pays your money and takes your choice!
the possibilities are endle
PhilWeaver is offline Reply With Quote Quote
Old 18-12-2009   #2
Trader Rating: 3
Dan has donated!
Absolutely brilliant guide. Cut about a cm off the bolt and still plenty of thread going in and even easier. Thanks. Dan
Thanks webbie thanked for this post
1.4 16v cinq complete 'ish'
Dan is offline Reply With Quote Quote
Old 06-01-2010   #3
Is this the same on the Cinquecento?
thedjse is offline Reply With Quote Quote
Old 06-01-2010   #4
Trader Rating: 3
Dan has donated!
yes
Old 03-10-2010   #5
Dubster's Dad
Andi9386's Avatar
Andi9386 has donated!
Can I just say, you DON'T need to remove the Engine mount.
Get a small block of wood & a trolley jack, place the block on the jack, and place the jack under the sump, then lift the engine up a few mm then you can get the the bottom adjuster bolt with a 16mm open ended spanner.
I did this a few weeks ago on my Sei Sporting, hence whay I said you don't need to remove the engine mount.
Big thanks to Ming (ycming) & Steve (Clock34) for the help getting my beast running again.
Dislikes thedtjs disliked this post
Quote Originally Posted by ycming View Post
Owning it is the easiest thing keeping it on the road is the fun bit
Andi9386 is offline Reply With Quote Quote
Old 28-02-2011   #6
Post Re: Seicento 1108 Alternator removal and refitting
Have just taken the alternator off my daughter's 1.1 Seicento SX. The advice is spot on, the top bolt does foul the engine mounting a little as you remove it, but it comes out with a bit of downward coaxing and 17mm open ended spanner. Taking 5mm off the end should leave enough clearanceto get it back in comfortably and with enough threads engaging to nip up tight.
Thanks very much for the advice. Saved me taking the engine mounting off which would make an already unnecessarily complicated procedure just crazy. FIAT - engineering by Roald Dahl ! Most alternators I've changed on other cars have taken about 15 minutes.
Likes Lewis P Abz liked this post
dadmechanic is offline Reply With Quote Quote
Old 30-09-2012   #7
Fantastic guide my alternator was seized solid after sitting for some time this guide helped extensively, I didn't cut the bold just inserted it from above the mount.
Lewis P Abz is offline Reply With Quote Quote
Old 21-12-2016   #8
South Africa
Quote Originally Posted by Radlet6 View Post
[BREAK=Removing the alternator]
1. Disconnect the earth lead from the battery (for safety - don't want to be shorting any electrics here do we?). Discoonect the two wires from the back of the alternator (one is a simple terminal and the other is bolted on). This done you can attck the mounting bolts.
2. You will need to initially loosten the mounting bolts with a 16mm spanner as the allen key won't be beefy enough. However, when loostening the top adjusting bolt use an open ended spanner and not a ring spanner. The reason is it gets trapped by the drive belt and wont budge, which means you have to cut the belt like I did (I was replacing the belt anyway, but that's not the point)
3. Once loostened you will find it easier to continue to remove them with the allen key. Fully remove the bottom mounting bolt first and then the top adjusting bolt.
4. You will find that in the final stages this bolt will foul the engine mount, but by holding the alternator at an angle and with some patience you should be able to get the bolt out.
[BREAK=Putting it back]
This is where my FIAT mate got cocky: "Yeah it comes out ok but it won't go back herrrr herrrr herr". WRONG!!!! it will and here's how.
1. Take the bolt you intend to use as the top adjuster bolt at cut approx 0.5cm off the end (that's half a cm not 5) - there is plenty of thread on the bolt and cutting this off the end makes no difference.
2. Carefully file the end of the bolt and the lead in to the thread to make screwing back easier and to avoid it becoming cross treaded. If you don't there is a chance it may go in cross threaded and knacker it all up. It is an idea to try it in the screw thread without the alternator first to see how easy it goes back in. If it won't a bit more work is needed.
3. You will find the top bolt goes back in easy peasy, especially if you do the majority of the tightening up with the allen key. It is easier to use this whilst keeping tension on the drive belt, and will nip it up sufficently to stop it moving whilst you get the spanner on it.
[BREAK=Final Stages]
1. Conect all the electrics back up, replace the plastic wheel arch bits and stick the wheel back on
2. And remember always use axle stands when working under your car - never rely solely on the jack.
[BREAK=Why Bother?]
Yes I know that the engine mount is only three bolts, but you have to find a way of supporting the engine without the mount. Easy when you are a main dealer full of equipment, not so easy at home; and I dont fancy renting a hoist just for this either.
The only other way is a trolly jack under the sump (feasible - but not really recomended that one).
Plus once it is done, it is done for good and you never know when you might need to remove the alternator again.
Where can i buy a 2002 seicento sporting anlternator belt, can't get it in South Africa
andre0041 is offline Reply With Quote Quote
Old 21-12-2016   #9
South Africa
Do you know where i can get a generator belt for 2002 seicento sporting, non in South Africa
Old 21-12-2016   #10
South Africa
Do you know where i can get a alternator belt for 2002 seicento sporting, non in South Africa
Old 07-08-2017   #11
I tried to do this at the weekend on my 2002 Seicento. two questions:
1. What is the best spanner to get at the top bolt? I couldn't get enough torque on a standard length 16mm open ended spanner, and (as you say) a socket set is no good. Do you use an extra-long 16mm or a stubby spanner, or something else? I didn't have the tools so gave in.
2. What is the allen key for? My alternator just has the two 16mm bolts.
PS, what I find irritating about this is that this whole job needs to be done to get the timing belt case off. My alternator is fine, I just need to access the timing case.
CasLad is offline Reply With Quote Quote
Old 17-12-2019   #12
I didn't know about the removing the engine mount thing, although it was obviously a bit tight getting the bolt out and a daft design. Rather than chop the end off the bolt (which was plan B) I filed about a 1.5mm chamfer on the hex head of the bolt which just gave enough clearance for it to straighten up as it entered the hole, but left plenty of flat for the spanner to grip on when tightening up. Be sure to leave the bottom bolt loose so the aternator can move about as you get the upper bolt in.
Airship17 is offline Reply With Quote Quote
Old 17-12-2019   #13
@CasLad The bolts have a socket for an allen key in the head, as well as the hex flats
Comment
Search this Guide:
(G) cinq tailgate window removal and refitting AngelUK Cinquecento / Seicento 0 10-07-2006 07:51
(T) Fog light removal/refitting bulldog5046 Marea 2 12-03-2006 12:23
(T) Fog light removal/refitting bulldog5046 Bravo / Brava 3 10-03-2006 13:42
