arc said:thermostat?
its not needed, the oil still heats up very quickly and maintains a constant 100degrees, so perfect, as you want your oil to be between 90-110degrees.
I'd rather it took a little longer to heat up than run about with 145+degrees on the oil as its starts to break down at that heat and then the turbo bearings are going to have a short life.
