Old 31-05-2005   #1
Unhappy blocked screenwash
My screen wash appears to be blocked - any advice on how I can unblock it?
I have a punto
helent is offline Reply With Quote Quote
Old 31-05-2005   #2
Fat pigeon... APPLE!
JonnyBoy's Avatar
Trader Rating: 1
JonnyBoy has donated!
Re: blocked screenwash
Try poking the nozzles with a pin to unblock them. If that doesn't sort it, check if the washer motor works - it should make a buzzing noise when you operate the washers.
Past: '91 Uno 45 Formula; '94 Punto 55SX; '58 Bravo 1.9 Multijet (150BHP) Dynamic, with extra toys
Present: Several, but nowt Italian...
JonnyBoy is offline Reply With Quote Quote
Old 31-05-2005   #3
hi friends :waves:
Liam's Avatar
Liam has donated!
I always takeout the nozzles and place them in a container with soapy hot water and leave them for a bit, once cleaned you can blow through them to make sure they are working.
Liam
Yes it's really me!
97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND
Liam is offline Reply With Quote Quote
Old 01-06-2005   #4
OK
So how do i remove the nozzles?
The nozzles are definitely blocked as the motor works and i have screenwash in the reservoir.
Old 01-06-2005   #5
If the motor is working but cleaning fails and it seems there is a blockage in the pipe, vinigar is the water will work a treat.
[CENTER][B][COLOR=red]Gaz[/COLOR][/B][/CENTER]
smurfhead is offline Reply With Quote Quote
Old 05-06-2005   #6
hi friends :waves:
Liam's Avatar
Liam has donated!
The nozzles should pop out with a forceful push from underneath the bonnet.
Liam
Yes it's really me!
Old 05-06-2005   #7
J333EVO has donated!
If you live in a hard water area you may find the blockage is due to limescale build up, so remove them as suggested but stick them in the kettle when you are descaling it and it will do the same to your jets.
Aaron.
Cinquecento Abarth 1.4 16V 6speed track toy
Lancia integrale EVO1 Homologation model
MINI Clubman Hampton Edition Cooper SD
VW MK5 Golf R32
J333EVO is offline Reply With Quote Quote
Old 15-06-2005   #8
David C has donated!
There are also one-way valves in the water lines.
Both of mine blocked up.
Cheep replacement ones from Halfords fixed the problem.
David C is online now Reply With Quote Quote
Old 15-06-2005   #9
Trader Rating: 10
dave has donated!
fuse wire is good for un blocking, and a table spoon of vinagar in the washer bottle every time you fill up keeps them clear
“The further a society drifts from the truth, the more it will hate those that speak it.”
Old 15-06-2005   #10
JonnyBoy's Avatar
Trader Rating: 1
Quote Originally Posted by David C
I'm a cheapskate, I took mine to bits, cleaned it and it works fine now
(G) Fuel tank filler vent blocked and cut outs Mazz0 Uno 9 22-07-2015 08:44
(T) Screenwash joecinq Cinquecento / Seicento 17 26-12-2004 21:00
(G) is it the fuel pump or a blocked tank vent.. lashlondon Uno 8 24-09-2003 20:58
