Hello everybody (my first post),
I've recently bought Brava '97 automatic (with 71K kms) and found a strange problem which could not be detected before purchase, as it would only show up during cold start.
After the cold start in the morning the engine starts easily and runs smoothly, but pressing the accelerator pedal seems to choke it, and I have to let it run for some time before the engine will rev up.
The main concern, however, is that as soon I shift from P to R or from N to D, a kind of metal grinding (or rattling) erratic noise starts coming form the engine. After shifting back to P or to N the noise goes away. What I usually do then is drive slowly through the driveway (about 100 meters), basically without pressing the acc. pedal, after which the noise is practically gone. Once I noticed a flashing "gearbox failure" light which went away after restarting the engine.
Otherwise, when the engine is hot it runs perfectly and without any noise, and shifting to any gear is flawless. The gearbox and engine oil levels are normal, and both oils have been changed few weeks ago.
A guy who sold me the car told me that a "pump takes some time after cold start" before I should start driving, but I don't know which pump (oil?) he was referring to and if that was correct at all.
Any idea what's happening and if it looks like a serious problem? (My suspicion is that the gearbox somehow does not have sufficient oil right after the cold start, and that the noise comes from the rotating gearbox parts...
