Old 18-07-2006   #1
Exclamation Jtd 105
just been down to my local Fiat specialist(Firela,stockwell.top dudes BTW) to purchase a few things which included a new waterpump.
wat i would like to know is,is there a gasket that goes on the waterpump?
thanx
plc143 is offline Reply With Quote Quote
Old 18-07-2006   #2
Lebanon
Re: Jtd 105
Quote Originally Posted by plc143
thanx
Hi there, yes there should be a gasket between the coolant pump housing and the cylinder block. There's also an O-ring seal betwen the pump itself and the housing.
TheCROW is offline Reply With Quote Quote
Old 18-07-2006   #3
Re: Jtd 105
Thanx for that Crow,looks like i`ll have to go back & get them.
Old 19-07-2006   #4
jug
blessed are the apostates
jug's Avatar
Trader Rating: 1
jug has donated!
Re: Jtd 105
they sold you a pump without a gasket, thats what you get for going to fiat. your local motor factors would have told you that a gasket is needed. and they would have charged less. lesson learnt?
2.0 twinspark veloce
jug is offline Reply With Quote Quote
Old 21-07-2006   #5
Re: Jtd 105
the dude wanted £34 squid for the SKF waterpump but he gave it to me for £25 & seeing as i`d just got a MAF(bosch) for £115+alternator belt for £15(was £17.85) i`m happy.
Old 21-07-2006   #6
zombie nation
Hellcat's Avatar
Trader Rating: 3
Hellcat has donated!
Re: Jtd 105
Waterpump is cam belt driven isn't it?
Drives: Fiat Multipla Eleganza , Owns: Alfa Romeo 159 2.4JTDm
Hellcat is offline Reply With Quote Quote
Old 21-07-2006   #7
Ireland
Re: Jtd 105
There's no gasket on the water pump, just the O-ring around it..
Owen.
Faster Horses, Younger Women, Older Whiskey and More Money.
'01 Bravo JTD100, '98 Coupe 20VT
stylers is offline Reply With Quote Quote
Old 21-07-2006   #8
Re: Jtd 105
hellcat,got 1 of those aswell,wat i mean is the Other belt
stylers thanx for the info, havn`t got round to it yet but will ask @ the parts
shop just to make sure.
Old 22-07-2006   #9
zombie nation
Hellcat's Avatar
Trader Rating: 3
Re: Jtd 105
You got the new cambelt tensioners too? Don't change the belt without the tensioners.
Old 22-07-2006   #10
Re: Jtd 105
Hellcat got that from shop4parts +
oil filter
fuel filter
air filter
timing belt
timing belt tensioner(adjustable)
thanx
Old 22-07-2006   #11
Ireland
Re: Jtd 105
have you also got the idler roller (the smooth one).. make sure this is replaced or otherwise ok (no rocking or play or signs of grease leaking from it)..
Owen.
Old 22-07-2006   #12
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: Jtd 105
Quote Originally Posted by jug
Firela are not assoiciated with Fiat in any way Jug.
Old 22-07-2006   #13
Re: Jtd 105
idler roller??
wats this?never heard of it.
Old 23-07-2006   #14
jug
jug's Avatar
Trader Rating: 1
jug has donated!
Re: Jtd 105
its just another of the many things the timing belt goes around, i know some alfas that apparently have been known to suffer timing belt contamination or premature wear when the roller isnt changed with the timing belt. im not sure if the JTD engines have the same issue but its always worth while checking the conditon of all parts when you do a belt change and replace anything that looks overly worn. for example sometimes tensioners are still in great condition when you do the first belt change and dont really need doing till the second change, and its the same with any roller, and the water pump. i know people will shout at me for saying it but its true. you have to assess the conditon of the car when you do the job, unless you like the better safe than sorry approach in whihc case replace the whole lot. its up to the individual owner, i only changed my belt recently at 60k because everything else seems perfect and unlikely to need changing anytime soon.
Old 23-07-2006   #15
zombie nation
Hellcat's Avatar
Trader Rating: 3
Re: Jtd 105
A lot of it is to do with if you know the history of the car. I always change cambelt within a month of buying so I know where I'm coming from. They're driven quite hard so will get a belt change at about 50k after purchase.
(T) Marea Weekend 105 JTD - Performance b1gduk Marea 26 30-07-2013 16:15
(T) Gutless Marea 105 jtd elx Owlesque1 Marea 1 22-06-2006 19:51
(T) A/C problems 105 JTD 2000(W) adjessop Bravo / Brava 3 26-04-2006 09:19
(G) All 105 JTD owners - Post your times here b1gduk Marea 6 03-02-2006 17:55
(G) A couple of questions about a Marea 105 jtd Delanet Marea 4 04-10-2005 19:44
