J Jack007 New member Joined Jun 23, 2006 Messages 2 Points 1 Jun 23, 2006 #1 speedometer, fuelmeter and heatmeters are not working. How to open that meterbox or any other advices? Service would like to replace hole metering system, ($$$):bang:
Andy_sx Established member Parked in the garage Joined Dec 2, 2005 Messages 1,972 Points 267 Location Isle of Sheppey kent Jun 23, 2006 #2 its usually just a case of removing the dials from the dash. there are 3 allen key screws at the top, and 2 at the bottom. take out the dial unit and then disconnect the leads from the back, then reconnect. this should fix it
jug blessed are the apostates Parked in the garage Joined Nov 28, 2005 Messages 27,935 Points 3,763 Location Durham Jun 23, 2006 #3 i agree it usually fixes the problem if you disconnect the wiring then plug it back in.
OP OP J Jack007 New member Joined Jun 23, 2006 Messages 2 Points 1 Jun 23, 2006 #4 Hi! Thanks, now it works Just remember lower the steering wheel and there is one extra screw inte fuse box. Saved 500€ , that Fiat service is useless:nerner: Last edited: Jun 23, 2006
T14086 Patron member Written a guide Joined Sep 12, 2004 Messages 39,858 Points 7,250 Location Preston Jun 23, 2006 #5 Jack007 said: Saved 500€ , that Fiat service is useless:nerner: Click to expand...
