Old 20-05-2006   #1
Question KEYS Question
Hello all,
I have been reading all the keys related threads for the past 3 hours and still couldnt get satisfactory answer hence starting the thread.
I bought a brava 1.2 last week. It has just one red key which is being used to run the car. To my wonder, after accidently bumping into "keys" thread, where someone has suggested not to use the red key as it will reprogrammed the ecu everytime the engine is started. I am terrified as I have to make a duplicate keys, but that is not the problem.
The main question here is if I make a duplicate of the red key, will it be clone of the red key or will it be the slave key similar to the blue key? Is it possible to make blue keys from a red key? There is no satisfactory answer anywhere on the forum, so would like some real good answer to this.
neoseal
neoseal is offline Reply With Quote Quote
Old 20-05-2006   #2
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: KEYS Question
Go to dealer & get 2 blue keys....its that simple.Dealer can also prog them or you can do it yourself.Is that a really good answer?
Old 20-05-2006   #3
Trader Rating: 1
JoskeJTD has donated!
Re: KEYS Question
You have the important red key, go to Fiat get them to order you two new keys and get them programmed in. You will need the red key and code card. Code Card costs approx 15 from Fiat.
I wouldn't use the red key for long as a permanent measure.
JoskeJTD is offline Reply With Quote Quote
Old 20-05-2006   #4
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: KEYS Question
card is £5.00 but some folk here have got it for £2.00
Reason you shouldnt use red key is because the code system is expecting a key prog procedure to be carried out which obviously doesnt occur,can confuse(even lock out)the system.
Old 20-05-2006   #5
Re: KEYS Question
Thanks all, info is useful and will do the same but the question is still unanswered, "Is the new duplicat key, the clone of original red key or it is just a slave key?"
Old 20-05-2006   #6
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: KEYS Question
You dont get a duplicate you get 2 slave keys.You cannot clone the red key.
p.s,you dont need a key card
Old 20-05-2006   #7
Re: KEYS Question
Thanks T14086, it is just I was going thru this thread
https://www.fiatforum.com/bravo-brav...highlight=keys
where the issue of cloning is highlighted and so am bit worried of red key cloning. Thanks for the info.
Old 21-05-2006   #8
jug
blessed are the apostates
jug's Avatar
Trader Rating: 1
jug has donated!
Re: KEYS Question
i got my red key cloned for about 20 at timpsons, it looks blue but it has the same code as the red key and does allow me to program blue keys into the ecu so it is a clone of the red key. to create a blue slave key you can copy the metal part of the red key but then add any valid code that is different to the red key. you can get valid codes from other fiat keys. a cinq code has programmed into a bravo ecu with no probs before. timpsons can read the code from any key and then copy it onto one of their keys. if you have a friend with a fiat that uses a red key style immob just get 2 codes from their keys and transfer them onto 2 blank slave keys, then use the usual key code programming sequence with the original red key to program the two new blue keys into the ecu.
2.0 twinspark veloce
jug is offline Reply With Quote Quote
Old 21-05-2006   #9
Re: KEYS Question
Jug your views differ from what T14086 says and I think the same as you, the new keys will be the clone of the red key and will function as red key irrespective of its look. So I have to get two codes and programme it into new keys, which will be different from the red key code. Then programme ecu according to new blue keys. Wouldnt this mess up the ecu, for the red key code?
Who will programme the ecu according to new blue keys, can I do it myself or I will have to go to dealer?
Now am bit confused.
Old 21-05-2006   #10
Forum moderator
Helz's Avatar
Trader Rating: 3
Helz has donated!
Re: KEYS Question
It's not a different view on the matter, just a different way of doing it - T14086 suggests you can go to Fiat to get slave keys made, jug suggests you can use the key barrel from your red key and code from another Fiat key (with the same immobiliser system), which while slightly more complicated, will probably work out cheaper. Choice is yours
Helz is offline Reply With Quote Quote
Old 21-05-2006   #11
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: KEYS Question
Right can I end this please!!!
You have red (master) key yes? And you want 2 blue (slave) keys yes?
OK here goes......
1)go to dealer/timpsons/woolworths/sunday market/asdas wherever you want to get 2 blue keys. I state dealer because alot of cheaper keys that you can get can sometimes have difficulty programming thats all not because i'm biased.
2)Get keys cut to same pattern as your red one.
3)Leave the shop/market/supermarket(delete as appropiate)
4)Try cut keys in car door to make sure they are cut correctly
5)Get in car
6)put red key in ignition & turn on,wait for code light to go out(about 3 secs)
7)take out red key & put one of the blue keys in,turn ignition on,wait for code light to go out(3 secs)
8)take key out & put other blue key in,turn ignition on,wait for code light to go out(3 secs)
9)take blue key out & put red key back in again,turn ignition on,wait for code light to go out(3 secs)
10)take red key out.
11)try both blue keys & make sure engine starts with them both.
12)put keys on key ring
13)drive home
14)switch on PC & access Fiat forum website
15)Donate 5.00 after all you have saved
The end
Old 21-05-2006   #12
zombie nation
Hellcat's Avatar
Trader Rating: 3
Hellcat has donated!
Re: KEYS Question
I take it that the blue keys that come from dealer/timpsons etc have their own code, and that you teach the ECU to allow that code, rather than programming the key with a code that the ECU allows?
Drives: Fiat Multipla Eleganza , Owns: Alfa Romeo 159 2.4JTDm
Hellcat is offline Reply With Quote Quote
Old 22-05-2006   #13
jug
jug's Avatar
Trader Rating: 1
jug has donated!
Re: KEYS Question
thats right hellcat, the blue key has a code which the ecu can learn, it can be any code as long as its different to the red key code which the ecu has permanently stored. the ecu learning process (as described by T14086 above) only works if you have 2 blue keys & 1 red key, if you only have one blue it wont work because the ecu expects a 3 key sequence, you cant use the same blue key twice in the sequence, thats an annoying bit that im sure fiat stuck in to get more money from key making.
Old 22-05-2006   #14
zombie nation
Hellcat's Avatar
Trader Rating: 3
Re: KEYS Question
What is the range like for these keys? Could I wrap my single key in foil to turn the barrel, and use one of Bunny's blue keys for the code?
If I got a pair of keys from Timsons will they already have a code? If so why do they offer to clone your current blue key? How do they change the code?
Lots of questions!
Old 22-05-2006   #15
jug
jug's Avatar
Trader Rating: 1
jug has donated!
Re: KEYS Question
i tried wrapping a key in lead plate actually, while i held a cinq key next to it, but that didnt work so i learnt the hard way that you need 2 blue keys, or a cinq key that will turn in the ignition.
the machine at timpsons has 2 modes, capture and write. in capture mode they put a key in the machine and it reads the code and displays it. in write mode it will write the last captured code to whatever key is in the machine.
if you put one of my keys in the machine you could capture my code, then you could stick a virgin blue key in and write my code to one of your new blue keys. you could then teach that code to your ecu. then we'd be code brothers
(T) Spare keys won't encode Turbolento Punto (Mk2/2b) 1 27-03-2006 22:55
ford fiesta key question sorry lol thefishdude Leisure Lounge 29 09-01-2006 22:06
(T) More about keys!! gsbellew Marea 6 27-04-2005 22:06
Answering The Previous Question Dr_Pepper Leisure Lounge 35 25-11-2004 14:25
(T) Red/Blue/Black keys HP Cinquecento / Seicento 0 07-06-2003 03:56
