Old 2 Days Ago   #1
South Africa
oil leak 1600 16v
engine has small leak while driving, when parked oil dribs at r.h. front corner of engine.oil filter does not leak. replaced oil seals on crank and auxiliary shaft which was not leaking. can someone help, the leak is very annoying
Hotnot is offline Reply With Quote Quote
Old 2 Days Ago   #2
Finland
Re: oil leak 1600 16v
Sure it is engine oil and not transmission oil? The differential is sealed by rubber on the driveshafts and if those are original, they might have started cracking and oil might travel across the subframe.
Replaced mine years ago and first tough it was the engine.
As for engine, filler neck or the dipstick tube loose on the block? Or just traveling down from the rocker covers?
Otherwise, clean and see where oil or other fluids starts appearing?
Neverth is offline Reply With Quote Quote
(T) Punto mk2 16v 2002 Oil Leak Iceberg31 Punto (Mk2/2b) 5 29-11-2018 13:14
(T) 16v oil leak. oldhammer Punto (Mk2/2b) 21 10-07-2013 00:39
(T) punto mk2 1,4 16V Drainage bolt oil leak chris lar1968 Punto (Mk2/2b) 6 04-05-2012 22:46
(T) Oil leak 16v Jonnybobs Punto (Mk2/2b) 2 02-03-2012 20:08
1.2 16v major oil leak Alan Mac Tech Talk 1 23-08-2010 11:47
