Old 10-06-2015   #1
Malta
Slow Passenger Window Solution
So, I know this has been posted before but it has never been actually solved. Now I'm ready to take apart the whole interior to solve this. Now my passenger side window has been slow since I owned the car, I replaced the window switches (all three of them), replaced the window motor and lubed it like theres no tomorrow. Same Problem.
So I started by isolating the problem, removed the switch and connected a 12V computer power supply to the white/violet and white/red wires, and it goes down normally, so the motor, door wiring and rubber/lube are out of the question.
Now I'm turning to relays/fuses/wiring. Been testing voltages between the red and orange/ red/green wires on the passenger side switch (these two wires act as a ground through the driver side switch) and there is always 12V between the wires at both switches (driver and passenger sides), so +12V and ground connections are good.
The problem arises when the window is operated, (passenger side) as the window goes down, only 9.5V is supplied to the motor and when going up, only 7.5V :O is supplied to the motor (no wonder it goes up slow) , at the driver side switch, the voltages drop to 11.5 when going down and 10V when going up.
So the next step is to check the connections between switches (I need to take out the wiring diagrams for this one), check the relays and fuses for possible corrosion causing the voltage drop.
Any help from anyone is appriciated, especially if you have any electrician experience
I'll try to keep this updated until it is SOLVED
Likes Adrian Bravo liked this post
maniacbravo is offline Reply With Quote Quote
Old 10-06-2015   #2
Malta
Re: Slow Passenger Window Solution
I timed the driver side window using the car electronics, the passenger side window using the cars electronics and the passenger side window using the external power supply. The driver side window takes 3 second to go from dead bottom all the way up. The passenger side window on the cars electrics takes a whopping 9 seconds all the way up while on the external power supply it takes just 4 seconds.
Old 11-06-2015   #3
France
this sounds like a good project, i'll be interested if you make any progress. i'm not too hot on lectronics so i doubt i will be much help, but even so, out of curiosity, when testing the voltages, did you measure the circuit with, or without the motor connected, could the voltage drop be due to resistance in the motor or even the wires?
Marea Weekend 2002 Saint Moritz JTD 110 The thread
Marea Weekend 1999 ELX TD100 (DECEASED head gasket failure)
franglais is offline Reply With Quote Quote
Old 11-06-2015   #4
Malta
Yep when testing the motor was connected, I will try it again without it to see if it makes a difference but I doubt it. The driver side motor always gets 12v whether on or off so it is now a process of elimination to find the culprit. I'm suspecting a connector block or a corroded wire.
Old 19-06-2015   #5
Brava2001 has donated!
Vatican City
My Brava's passenger window has always been slow .... and I've been driving it since it was new .
Likes maniacbravo, Adrian Bravo liked this post
Brava2001 is offline Reply With Quote Quote
(T) Slow Passenger Side Window Solution? maniacbravo Bravo / Brava 0 12-02-2015 16:59
(T) Slow retracting Seat Belts, Is there a solution.... spoceto1003 Barchetta 16 26-04-2012 20:10
Slow Window Alex80 FIAT Boo Archives 2 21-11-2007 13:44
passenger window goes up really slow! ryan FIAT Boo Archives 10 11-09-2005 19:40
Elect Window running slow Solution Tom FIAT Boo Archives 0 15-11-2002 23:10
