Old 26-09-2005   #1
Blue key 'keyring attachment' loop broken off
Hi all,
The part on my Bravo's blue key that loops around the ring on your key set (I hope you know what I mean!) was broken when I bought the car, so I cut the 'ring' portion of the fob off as it was redundant, but now want to sell the Bravo, so I was hoping to try and either (a) replace the key or (b) fix it. The car is not remotely controlled, so it doesn't have batteries in, etc, but I was wondering whether it has any other parts inside the solid plastic fob that are particular to the car, like recognition chips, immobilisers, etc. I thought that if not, I could just get a new key cut, but if it does have stuff 'inside' it, then is there any such thing as a 'sleeve' available, that slides over the fob, and provides someway for a key ring to fit to it?
tony witney is offline Reply With Quote Quote
Old 26-09-2005   #2
Go on the Fiats!
Steven's Avatar
Trader Rating: 8
Steven has donated!
Re: Blue key 'keyring attachment' loop broken off
You will need to have it cloned. They are programmed as they operate the Code immobiliser.
2015 Fiat Panda Pop
Steven is offline Reply With Quote Quote
Old 26-09-2005   #3
Quote Originally Posted by Steve
Thanks. I called Fiat and they wanted £40 for a replacement key. Does anyone know where I can get a cheap(er) cloned key?
Old 26-09-2005   #4
α ψΨψ Ω
alainax's Avatar
alainax has donated!
timpsons do them for bout £20 xxx
alainax is offline Reply With Quote Quote
Old 26-09-2005   #5
Just drill a hole near the top of the key. Just dont go near the front of the key as that is where the transponer is.
F.I.A.T. -- Flipping , Italian , Automobile , Tat . :)
FiatExpert is offline Reply With Quote Quote
Old 27-09-2005   #6
Quote Originally Posted by FiatExpert
I'd be a brave man if I were to take your advice on that premise! Where exactly should I drill the hole? If you can visualise the key, the end where the hole USED to be has been removed all the way down to the bottom of the original hole position, so it is completely flat.
Now, should I drill in a central position, or to the right or left (from the side of the key with the 'FIAT' stamp. Sorry to be so pernickety here, but the last thing I want to do is to bugger the only blue key I have!
Thanks.
Old 27-09-2005   #7
Go on the Fiats!
Steven's Avatar
Trader Rating: 8
Steven has donated!
I would suggest that you don't drill your key.
2015 Fiat Panda Pop
Old 27-09-2005   #8
Trader Rating: 10
dave has donated!
or drill it after you have got it cloned at timpsons, then you have a spare if you fcuk it up
“The further a society drifts from the truth, the more it will hate those that speak it.”
Old 27-09-2005   #9
If you only have one key, then do get a clone cut. I would not like you to break the only key you have , on my say so.
Old 27-09-2005   #10
I've attempted to apply devcon putty to the fob, and its drying at work overnight. Hopefully when I get to work in the morning I'll find a hardened moulded fob-end, and not some soggy mess over my desk !
I'll have to grind the putty down to shape and then drill a hole for the key ring. If the devcon falls off, I can always superglue it back on !
I'll let you know what transpires .
Old 27-09-2005   #11
Go on the Fiats!
Steven's Avatar
Trader Rating: 8
Steven has donated!
You weren't to know.
2015 Fiat Panda Pop
Old 28-09-2005   #12
Well, I affixed the devcon putty, waited for it to dry overnight then sanded it on a flat bed sander. After drilling the hole and cleaning I painted it with blue paint (metallic - looks very nice!) and it is now drying overnight.
The finish is very good except where I caught a bit of the rubber at the join, but the paint will hide most of that. The important things are that it is a really strong bond and that the key still works!
Jobs a good'un!
Old 28-09-2005   #13
Trader Rating: 10
dave has donated!
lets hope the signal can still get through
Old 28-09-2005   #14
Go on the Fiats!
Steven's Avatar
Trader Rating: 8
Steven has donated!
Hmm.... I'd say it will.
2015 Fiat Panda Pop
Old 20-10-2005   #15
Yep, signal got through fine, no problems!
(T) red key blue key??? gough1e Doblo 2 27-09-2006 20:23
Replacement Blue Key In Sheffield dave1814 Lets Talk FIAT 6 04-11-2004 13:10
Replace blue key cjras Lets Talk FIAT 6 18-09-2004 17:30
(T) Bravo Blue Key Problem norfie2004 Bravo / Brava 6 31-07-2004 02:43
