FIAT Auto Specialist Team
Thread Tools
Old 18-09-2005   #1
brava clutch problem
hi,
When I depress the clutch there is a rattling coming from the eninge. Yesterday I noticed that at one point it was incredibly difficult to get the car into any gear, however this problem stopped quite soon. Can anyone let me know if this is a problem with my gearbox or my clutch? And what the problem is exactly.
Thanks in advance for you help.
wretched
wretched is offline Reply With Quote Quote
Old 18-09-2005   #2
Re: brava clutch problem
try adjusting your clutch cable see if that helps
Gaz2005 is offline Reply With Quote Quote
Old 18-09-2005   #3
Whaddya mean too old?
Deckchair5's Avatar
Deckchair5 has donated!
Making a noise when you put the clutch down and intermittent gear selection problems sounds like a clutch bearing on its way out. If it is it usually gets worse fast so I'd start finding quotes for a new clutch.
Some clutch bearings can make a noise for quite a while without giving up but as you are already experiencing gear selection problems then it may not be long. When the bearing finally gives up it's quite sudden and the car is pretty much undriveable unless you're really good and the roads are quiet
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline Reply With Quote Quote
Thread Tools
(T) 1999 Brava air conditioner problem monk Bravo / Brava 3 06-07-2017 15:11
Abarth 130TC Clutch failure. Morty Mort Lets Talk FIAT 8 31-07-2005 02:06
(T) Brava 1.4 Engine problem Cheyenne Bravo / Brava 5 14-09-2004 18:16
(T) Funny Clutch problem Matts Dad Punto (Mk1) 2 19-11-2003 00:49
Brava lockup problem Kensho Lets Talk FIAT 1 11-11-2003 03:05
