Old 04-03-2011   #1
Ireland
That bloody bolt!!
I'm replacing my rear arm have the whole thing stripped out (hub etc etc) and the baby is ready to come right off except for one problem.There's one big bolt still holding the arm in and is down right refusing to come out,i've hammered,twisted,pulled and cried trying to get the darn thing out but it won't budge .It's twisting and letting me take off the nut at the back (exhaust side) which is telling me there is movement but just not in the right direction,has anybody got any idea how to remove this bolt?
abarth simpson is offline Reply With Quote Quote
Old 04-03-2011   #2
Re: That bloody bolt!!
Well just to cheer you up in the past ive had the whole subframe off and cut the bloody bolt out, you can just get in with a blade down either side to cut off the bolt if you have one of those reciprocating saws.
The reason its turning is because its seized in the bearings and they are turning with the bolt.
jimmyybob is offline Reply With Quote Quote
Old 04-03-2011   #3
m20b25 has donated!
Ireland
Ive been there and spent a whole day at that bolt. What we did to get it out was heat it with the gas torch and hammer it, bit by bloody bit and saw the arm with a grinder. Alternatively drop the tank and use a similar sized bolt and hammer the bolt out. Use plus gas if youre not using heat to get it out
m20b25 is offline Reply With Quote Quote
Old 04-03-2011   #4
Ireland
thanks for coming back to me boys,looks like i'll be getting the saw and ending this 2 day episode.Are those bolts a common size by any chance for when i'm putting the new arm on?
Old 05-03-2011   #5
You will need to get a new bolt from fiat.
Old 10-03-2011   #6
Ireland
got it out and replaced it in the end,just got on the grinder to get the arm out and got a new bolt from the scrap's,thanks for the help and sympathy
(G) Lost Exhaust Bolt - Bolt info Needed Hampson Punto (Mk2/2b) 2 20-10-2009 16:31
(G) Bolt crabman 500 9 29-09-2009 00:42
bloody regtransfers...... Jai Leisure Lounge 24 20-10-2008 13:18
(T) bolt tidus Cinquecento / Seicento 7 24-07-2007 22:54
(G) bolt tucka_5 Cinquecento / Seicento 9 04-09-2006 12:43
