Technical bravo wheel bolts
gihan798114
Sri Lanka
hi all,
recently few of my bravo mk1 wheel bolts has fallen down, the below image shows the bolts. the small bolt is the one that fell down, and i brought the large bolt which seems to fit perfectly but a bit too long, a noise comes when driving along with the long one, so i took it out.
the noise only comes only from the real wheels with the large bolt. i have also fitted one for each front wheel and no noise comes from there.
Neverth
Active member
Original steel wheel nuts, in the back you start rubbing the things inside drum brakes if they are too long.
Alloy wheels/spacers need longer bolts
OP
OP
gihan798114
gihan798114
Sri Lanka
agreed on that, i also think that the sound doesnt come from the front wheels because they are disk brakes, and the rear its because of drums. :confused:
