Hopefully someone can help me.....
I have a Fiat Bravo 2l HGT. The battery has been out of the car for over 3 weeks. We put a new battery in the car and the key code light now flashes when we turn the ignition on... When we try to start the car it does turn over but obviously will not start.....
I've read that the key code light should stay on and not flash if it's a problem with the key code.... We've tried starting the car with the various key's to see if it was a problem with the blue key we were using, as the battery inside the key was also very low.
I'm no expert at all... but would this be a problem with the Key's... or the ECU is it called..? or something else......
thanks
Joe
thanks
Joe
