I had problems with engine idle and cutting out for short amount of time 1-2 seconds and thought it was due to electrics. After changing plugs/ht leads and lambda sensor I took it to the garage and had them put it on there ecu tester after which they told me that the electrics were fine and that it was a mechanical problem so I should check the throttle body and the breather pipes. So could some 1 point in the direction of the throttle body and breather pipes on a 1.2 brava on a x plate.
Thanks.
Thanks.
