Old 23-09-2009   #1
1997 TD100 Bravo
Okay I have to do oil change on my car I got the filter today going to do the change tomowrow, I have never owned a Euro car before so and I have manual for every model of this car except mine I guess Haynes don't provide for Diesel anyhow can someone tell me how much oil I need to put into my car? I guess I could just put some in and test level but thought someone could send me specs on it, and also where is my oil filter located on my car?
miguele26 is offline Reply With Quote Quote
Old 23-09-2009   #2
Trader Rating: 1
JoskeJTD has donated!
Re: 1997 TD100 Bravo
My Bravo JTD takes 5L of oil, the oil filter is on the front of the engine, once underneath the car and you look up, you can't miss it.
JoskeJTD is offline Reply With Quote Quote
Old 23-09-2009   #3
What fix was it you wanted to know about?
Old 23-09-2009   #4
Trader Rating: 1
Quote Originally Posted by miguele26 View Post
Sorry was a typo.
Thanks miguele26 thanked for this post
Old 23-09-2009   #5
zombie nation
Hellcat's Avatar
Trader Rating: 3
Hellcat has donated!
Dunno if your TD will be a copper washer sump plug or a taper.. The copper ones you should either replace or aneal the copper washer. Get the engine warm before you start - cold diesel oil takes forever to drain. Not too hot though or you won't be able to touch it!
As for capacity I believe it's just shy of 5L..
Drives: Fiat Multipla Eleganza , Owns: Alfa Romeo 159 2.4JTDm
Hellcat is offline Reply With Quote Quote
Old 23-09-2009   #6
Copper sump plug or Taper? What do you mean by this?
Old 23-09-2009   #7
zombie nation
Hellcat's Avatar
Trader Rating: 3
taper plug:
copper washer sump plug:
Old 27-10-2009   #8
Hi!
Its 4.0 litres with used oil filter or 4.5L with new (empty) oil filter!!!
***Be very careful checking the level once you've put 4.0L in as there may still be some in the sump etc., and overfilling diesels can cause 'em to overspeed and destroy themselves - I had a Xantia with an XUD engine that was complaining of low oil level due to a dud sensor, as a result I put too much in and that's what happened!!!***
A good quality 10W/40 diesel-spec. oil should be fine!!!
Chris Williams
Chris56000 is offline Reply With Quote Quote
Old 27-10-2009   #9
Malta
i believe the JTD100 requires the same type of diesel like the 75TD? if yes, then the manual states Selenia Turbo Diesel Oil. better to check with someone else too though
kajl is offline Reply With Quote Quote
(G) Fiat Bravo GT TD100 miguele26 Bravo / Brava 0 22-08-2009 22:30
(G) bravo td100 1.9 exhaust gkirk26 Bravo / Brava 1 14-04-2008 11:21
(G) bravo 1.9 td100 help gkirk26 Bravo / Brava 10 06-04-2008 17:52
(G) hi i have just bought a 1997 marea weekend td100 ramdonice Marea 3 30-10-2006 16:57
1997 Fiat Marea Td100 Elx Weekend Red dave Auction Watch 1 09-04-2006 01:56
