My bravo 1.6 mk1 stalls when I release throttle. Most significantly in 1st and 2nd gear. Also idling is not even when hot or cold.
I cleaned throttle body, idle step motor is new. I also measured injector resistance. Three of them are around 22ohm one of them is 16,5 ohm.
Could be injector fault? Injector light is never on.
I assume throttle sensor
Have someone similar problem?
