Can anyone help.
Arrived home from work to find the wife's Brava 1.4SX sitting on the drive with a pool of oil underneath. The oil is coming from the gearbox bell. She said the car was juddering a bit when braking/clutching.
I had this gearbox repaired about three years ago. The Mechanic then said Bravas suffered with oil leaking onto the clutch plate and this had caused the gearbox to fail. Could it be the same thing again?
Am just about to go out and start dropping the gearbox out, if anyone has any ideas or suggestions they would be welcome.
By the way it is definitely gear oil and not engine oil.
