Car is a Bravo 1.4 'S' Reg, and had the clutch replaced maybe 1000 miles ago. I got the job done in the cheapest, grottiest East Glasgow garage I could find, as I would normally do the work myself but was in the middle of Uni exams.
The clutch has juddered since I got the car back, but this seems to be reducing over time. I put the judder down to it being a new clutch.
Now there is a repetitive noise from the clutch that disappears the moment you apply pressure to the clutch pedal (and a visual check shows the noise disappears the moment the slave cylinder moves the clutch fork arm). This noise has been getting worse the last 200 miles, and to give an idea of the sound at first I thought it was a faulty injector. A rapid ticking noise.
As is now traditional for me, I post here for an opinion (usually Jugs!)......thanks for any opinions as to what might be causing this noise. Gear selection etc is fine.....
