VolvoV70T5
- Nov 8, 2007
- 19
- 8
Hi All, any help appreciated on this one as I am very close to taking my lump hammer to my wife's Brava :bang:
The long version is below, for people who don't want to read all that here's the short version-
Car drives okay (albeit very hesitant on accelleration while on petrol (drives perfectly fine on LPG though)
Has had new injectors recently, new coil pack recently and was driving fine.
Coming home from work one very hot after noon last week and the car just died and has refused to start ever since, I have just replaced the crankshaft sensor as there was spark at the plugs and this has made no difference.
The engine spins over no problem but it refuses to start on petrol orLPG due to no spark.
There is a fault being recognised by the ECU as the injector light comes on when cranking the engine.
I have an elm323 OBD reader, fiat 3 pin to OBD conversion cable and lapop etc but cannot get anything to read the codes.
Long version below-
Right, been driving my wife's Brava to work every morning as it's cheaper to do short journeys than in my Volvo, driving homefor dinner in the afternoon and the injector light came on, I was coasting down hill with my foot off the throttle at the time so thougth I had better check the engine was still running, attempted to acellerate and nothing so had to quickly pull off to the side.
All attempts to start the car failed and after a few tests I found there is no spark at the leads, the coil pack was fitted new about 6 months ago.
Previously on a few occasions while driving the injector light had come on and the car had died for a second but then ran on as normal and the injector light went out.
I have now changed the crankshaft sensor in the hopes that this is the fault (even though resistance readins at the connector check out fine) and the car still refuses to start and has no spark at the leads.
With the engine cranking there is 0.16v at each pin on the connector to the coil pack (all other componenets receiving 12v as they should) what should the voltage be at this connector?
Any help appreciated, I have tried to keep this as short as possible so if any further info is needed please ask away.
Thanks in advance,
Paul.
Long version below-
Thanks in advance,
Paul.
