G gkirk26 New member Joined Apr 1, 2008 Messages 10 Points 3 Apr 11, 2008 #1 hello again. this is the first time ive had a oil burner which will contrbute to my problem. i put an back box on expeting the normal brum brum, but it sounds the same. how do i get a brum noise out of my motor.
jug blessed are the apostates Parked in the garage Joined Nov 28, 2005 Messages 27,935 Points 3,763 Location Durham Apr 14, 2008 #2 it depends on the backbox you used? also remember a TD has lower rpm so less airflow, which has a big impact on the exhaust note.
