wiring loom was all there. the plug is the same....everything was simple.
i really hate to be a pedantic swine but i dont believe it was a "simple" case of connecting things up, and to save someone else the hassle of finding out the hard way i will demonstrate why i know you are fibbing when you say "wiring loom was all there. the plug is the same....everything was simple"
looking at the pic of the 1.6 engine on the floor i can clearly see the connectors and a few inches of their wires have been left on the engine.
for example, in the pic of the 1.6 on the floor the air temp sensor clearly has a few inches of wire and the brown connector still attached. same for the MAP, you can see its wire hanging off the manifold.
on the 1.4 the temp sensor's connector is different (check workshop manual if in doubt, 1.4 has a 4pin connector and 1.6 has a 2pin connector) so you could not have used it, you must have fitted the 1.6 connector to the 1.4 loom, and you must have firstly determined which of the 4 wire you needed to use by examining a wiring diagram of the engine management system. also, a MAP isnt even fitted on the 1.4 engine so you cant use wires that do not exist.
obviously you used the 1.6 connectors for all sensors, and spliced into the 1.4 loom, removing the 1.4 connectors in the process. it is important that anyone considering this converison is aware of that fact, and are not led to believe it is a simple case of connecting the 1.6 engine to the 1.4 loom.
i assume this connector replacement method was used for all instances where the connector is different (which the fiat workshop manual shows is almost all sensors), and the wiring was re-routed to suit the different positions. for situations where no wiring was availalbe surely you must have fitted the wiring, for example the MAP needed its wiring fitted and joining to the ecu connector.
i do not mean to offend you or make you look like a fibber, but i feel it is important that people understand what is required to do this conversion so they can plan how they will do it. it is not fair to mislead people, what happens when we get a reply to this thread in 6 months time and someone is saying "please help, my connectors are different" and then i have to tell them that they should have taken the connectors when they got the engine, and now they must go back and get them. they will say to me "but this thread told me the connectors were the same". that is the only reason i have wirtten this reply.
i personally believe your car was never a 1.4. all the pics show your car with a 1.6 engine, either fitted or removed, so i believe those pics are from a like for like replacement of the 1.6 engine. i do not make such accusations freely, but there are also some very good clues in the pics that it was originally a 1.6 (prize goes to anyone else who can spot them). a like for like replacement is as you describe it; "simple". are you sure you are not confusing a 1.4 to 1.6 conversion with a 1.6 to 1.6 replacement?
