are the front wings the same on the Bravo and Brava? they look the same but i just want to make sure. i know the marea and hgt are different.thanks
I thought i might aswell try and fix the wing before i fit the sideskirts.
they bolt on, its easy, i thought there was a single weld where it meets the sill but i was geting confused with another car (escort i think) so its simply a case of bolting it on, should take half an hour at most.
you'll never work in a garagetook me and my mate 5 hours to do his Bravo wing
yes they're only bolted on.bravowes2 said:so they just bolt off then coz i though they was welded
that sponge is just foam covered in a sticky coating, its used to block the gaps up, you can pull it out easily enough without damaging it. i had to do that when i laid the live wire for my amp through the wing.
