Thread Tools
Old 04-03-2019   #1
10w 50
JLR recommend an OEM version of their engine oils...I assume that the 10w50 Selenia is pure marketing and will be no different to that offered by the likes of Castrol?
DAVENN is offline Reply With Quote Quote
Old 04-03-2019   #2
Re: 10w 50
In a word - additives. Or to put it another way, no, not the same. Whether that means it matters or is better or worse is another question. If you can find another oil that conforms to the exact spec required by your car then it ‘should’ be ok; but why risk your engine to save a few quid.
Twinkletwinklelittlestar is offline Reply With Quote Quote
Old 04-03-2019   #3
Re: 10w 50
That's a very fair point.
Compared to the stuff I have to stick in my daily runner, the pukka Petronis isn't mega expensive.
Old 05-03-2019   #4
STOP! Hammer time!
306maxi's Avatar
306maxi has donated!
Quote Originally Posted by DAVENN View Post
Just put in anything from a decent brand that conforms to the spec. You won’t be “risking” your engine if you use something from Shell, Castrol etc etc despite what people will say.
Likes John202020 liked this post
306maxi is offline Reply With Quote Quote
Old 05-03-2019   #5
Re: 10w 50
Yep, too many people get hung up about what oil. As said, use oil that is the spec for your engine. More emphasis should be changing the oil & filter regularly, an engine will benefit from this far more.
jimboy is offline Reply With Quote Quote
Old 05-03-2019   #6
Re: 10w 50
Thanks chaps.
I do a 6mnth oil and filter change ( top extract method) on my other motor.
Think I'll do the same here.
Thread Tools
(T) 10W 40 in an 899? little J Cinquecento / Seicento 29 20-11-2011 10:57
Changed from 0w 30 to 10w 40 TONY55S Lets Talk FIAT 1 18-03-2011 21:45
(T) 10W/40 or 5W/40? 1.2 8V Mk 2 shaun200765 Punto (Mk2/2b) 6 14-08-2010 22:37
When you see 10w-40 what does it mean - An explanation oilman Lets Talk FIAT 1 16-01-2006 14:29
