Roads up here are a lot worse than you believe.. It will be Koni's the bilstein coilovers are lowering between 20 and 40 mm it seems. I'm scraping the front splitter on snow on our roads as it is now..
Took a long time, but yesterday evening i fitted Bilstein B14's. Wow!
Thanks for your comments
Quite satisfied with the car as is is now (have to do something about that squeeky rear brake though). perhaps something about the backbox later, but I'm content for now..
Regarding the drop, it is not as drastic as I thought, set the height midways in regard to bilsteins recomendation (10mm higher than delivered). I'll measure wheel center to fender edge later. The ride is a lot more comfortable than the original suspenders actually.
Off to read that link...
/B
The pogo stick nonsense is gone!
Ok, measured the drop now that it had time to bed in for a few days. Vertical distance from center of hub to wheelarch is about 340 to 345mm's both front and rear, this is with the height adjustment midways both front and rear (10mm to go each way). Regards to ride comfort, perhaps you had the sensation that felt the stock suspension get smoother when speeding on the motorway? (say at 160-170kph, not that I'll ever admit dong that ). The car now rides that smooth at 120kph . The pogo stick nonsense is gone!
No. but a month or two should have them settled
On the very little that I know about shocks I understood that it was recommended that you leave the shocks on the highest setting so that they 'break in' better and then after a month or so drop the height to the right level.
Looking at the pictures on the 'old link' they look the business.
But the adjustment on the Bilstein's is merely the ride height and not a damper setting.
Like I said there is no knob on this unit.I used the word 'shock' incorrectly - I meant the 'knob' on the whole unit i.e. the shock and the spring - which of course only applies to the front ones since the rears...
At least with a reputable make like Bilstein you should be able to get them re-conditioned when the 'time' comes.
