Thread Tools
Old 25-03-2016   #1
USA
Accessing 2012 500c high center brake light bulbs
Collective Fiat Wisdom,
How can I remove/open the high-center brake light assembly on my 2012 500C to replace one of the bulbs? Do I need to remove part of the retractable top's inner lining, and if so, how?
There are no visible screws, tabs, etc. on the exterior surface of the light assembly to remove or open it for access to the bulbs, which is why I suspect this operation must be handled from the car's interior.
The online User Manual, which supposedly covers both the 500 and 500C models, only has instructions for the 500 on this topic!
Anne
Anne Brennan is offline Reply With Quote Quote
Old 25-03-2016   #2
varesecrazy has donated!
Re: Accessing 2012 500c high center brake light bulbs
Quote Originally Posted by Anne Brennan View Post
Anne
Hi Anne, and welcome,
it's pretty quiet in the US 500 section..,
I would look in the Euro 500 section..,
I suspect the lights will be very similar
here's a link;https://www.fiatforum.com/500/223585...ml#post4158074
Charlie - Oxford - UK
Old 25-03-2016   #3
USA
Thanks, Charlie, will do. I'm surprised there's not a separate forum for the 500C like there is for the 500L and 500X. The differences may be relatively few, but they're significant!
Anne
Old 25-03-2016   #4
Australia
– Anne
Anne;
Someone posted about this a few months ago - I shall try to find the thread for you.
However, be advised the centre brake light on the 500C does not use bulbs. It's a sealed LED unit and individual parts cannot be replaced - only the whole unit.
Later.... Found it! https://www.fiatforum.com/500/347995...rake-lamp.html
Quote from Big Kev on 17/07/15 - "Re: High-level brake lamp. Well, actually I had a go at this last year (this is an old thread). The rear portion of head lining is uncliped, then four screws are removed to release the spoiler, then the whole LED unit can be replaced. On assembly, apply more sealant to the four screw holes to combat leaks, replace screws and headlining. Fiddly working in the back of the car (it is for me as I am a huge fella!) but not dificult for a competent DIY type.
The new LED unit is hellishly expensive though, at over 100!!!
Piccolo Nero e Bella is offline Reply With Quote Quote
Old 26-03-2016   #5
USA
Interesting that the entire LED unit has to be replaced, since the owner's manual lists a replacement bulb type (W5W). I have to assume that's for the 500, not the 500C. The lack of accurate documentation from Fiat is more frustrating than the repair!
Anne
Old 26-03-2016   #6
Australia
Anne
You're dead right there. As far as I recall the 500C supplement doesn't even mention the brake light. FIAT either assume it'll work forever or that every owner will return to FIAT for repairs.
Theoretically LED's should outlive the car but moisture often finds a way into the housing.
Old 25-07-2016   #7
Australia
Quote Originally Posted by AlexFox View Post
I have been trying to do this as well. Founf nothing on the web
If you follow the link supplied further up the page it appears the job is pretty straightforward. Unfortunately if any of the LED's are dead you'll have to replace the whole unit.
Old 25-07-2016   #8
Smile Re: Accessing 2012 500c high center brake light bulbs
– Anne
Hello, Anne - BigKev here
I have just seen this today and I would like to reiterate that the 500C does only have a sealed LED unit and not separate bulbs.
As I have been quoted from a previous post a couple of years ago, the LED unit must be removed from inside the car. Unclip the rear headlining and remove the four screws which secure the roof spoiler. The LED unit can then be unscrewed from the spoiler. I decided to put my old unit back when I discovered how dreadfully expensive these LED units are (well over 100 GB pounds, so a tidy sum in dollars!) Mine has half the lights still working so I will tolerate this until complete failure, due to the ridiculously high price.
If you do decide to remove yours, can I stress that the four screws securing the spoiler pass through the soft-top fabric so will need plenty of sealant to avoid leaks.
Regards,
Kev.
BigKev is offline Reply With Quote Quote
Thread Tools
(G) 500C - high level centre brake light Cledwen 500 19 19-02-2017 19:10
(T) 500C high level brake light access feemunter 500 0 17-02-2014 07:42
(T) High level brake light bulbs Rooflessdriver Panda 1 09-10-2012 20:33
(T) Accessing the rear bulbs jook Sedici 2 26-07-2011 09:33
Brava high level brake light bulbs Paul FIAT Boo Archives 4 12-07-2006 15:45
