- Sep 14, 2009
- 19,492
- 3,294
Found it! The u-tube to watch is:--"Kawasaki Z1-1396cc Super six 6 cylinder engine first start" When you have watched this film, watch how he casually describes how he he built his "V12" bike engine--the guy is plain BRILLIANT
Did you see how he extended and retimed the camshafts for the Super Six?
They were literally cut into cylinder sections with an angle grinder on his back lawn, then turned, assembled and timed in the lathe using old piston gudgeon pins to align the joints. Finally TIG welded using a special motor controller to turn the shaft at 1 rpm. Finally trued-up in true Allen style with a copper hammer and backing weight.
He did something similar with a Yamaha 16 valve FZR250R (limited to 45bhp at 14,500 rpm).
https://www.youtube.com/watch?v=pxsRHqPF5os
His Honda SS100 is a work of art. A V-twin made using two SS50 moped cylinders on a modified crank.
