i have a question about headlight adjustment mechanism on a 71 500
it has two adjustment screws. there is one spring from the frame and to inside of body .
the two adjustment screws have no springs. my guess is that there should be a compression spring that the adjustment screws pass through to apply counter tension to try to push the light frame away from the car body and the adjustment screws would pull back against those springs when the adjustment screws are tightened.
does anyone understand this mechanism. i think the missing springs should be between the car body and headlight frame with the adjustment screw passing through. ????
