Hi all!
So my carb (26IMB) is rebuilt and the Idle jet seems to control the idle by how you move it, though it's not smooth at lower RPM's. Reading the factory manual, only adjustments are supposed to be from mixture screw and idle screw. It never mentions the idle jet as an adjustment. I can get it starting, running, driving idling fine.... it's just idling at 1200 rpms instead of 8-9. I can adjust the mixture and idle screw until I'm blue in the face, but the idle doesn't drop to 8-900. If I turn the idle jet at all, the engine does drop, but then begins to run a bit rough. So I'm looking for possible solutions, any thoughts?
Does the idle jet have to be screwed all the way in to where it doesn't move, or is it adjustable?
I'm not a pro at carburetors by any means. I'm just trying to get it all dialed in, though its not cooperating!
Thanks!
Chase
Thanks!
Chase
