Hi all, this is my first post and thought I’d start a new thread as I couldn’t quite find the answer in any of the archives.
I’ve got my ‘67 500F with the original 110F engine up and running for the season with a new Distributor, plugs and leads so I took her out to stretch her legs a bit, down a few miles to the local Italian Market (fitting, right?). Was running strong until about halfway there when she sputtered out and stalled. I rolled her into a shop nearby who jumped me and got her going and put her under charge for a bit while we tried to sort out the problem. Eventually found the generator wire had shaken off, therefore the car was running straight off the battery until she ran out of juice. Easy fix, new connector and I’m on my way.
Unfortunately, I was caught up in traffic most of the way and had to keep her revved at the stoplights and eventually I lost her again. A couple jumps later I get her back home (along with some prosciutto and Mozzarella) and put her under charge with the wall charger. After dark I went out and unplugged her and closed up the garage for the night but before that I started her up. Crank was strong and turned over normally. Now here’s the question:
1) Under idle, after the full charge, the Generator light is on bright. It fades when I rev the engine but comes back on at idle. Is this normal? I don’t remember that before.
2) What tools/gauges/instruments do people use to check the voltage coming off the generator to see if it’s where it should be to keep the battery topped off?
3) Do I need to worry about the battery being fried after getting discharged so much?
4) after sitting for the winter is it possible/likely that the brushes need maintenance?
5) suggestions on what to check first?
Thanks!
Thanks!
