Thread Tools
Old 12-04-2019   #1
Tyre help
Looking for the right tyres for my 1970 500L and with new tyres do I need to get the inner tube things ? Thanks for help as the tyres on mine at mo look like they had their day
Johngray is offline Reply With Quote Quote
Old 12-04-2019   #2
USA
Re: Tyre help
The original wheels on that car would have run on something like the tire at this link: https://www.fiat500ricambi.com/fiat5...+Rims/WL1001/?
These are tires that require inner tubes to be fitted because the wheels don't hold an airtight tubeless seal safely. There are more modern wheels that accept more modern tubeless tires, if you prefer that. But of course then you're into new wheels to go with your new tires. I'm running with the original wheels and new old-style tires with inner tubes, because my car doesn't go fast enough for any of this to matter!
Likes Johngray, lazylobster, berkeleyman liked this post
1971 500L
1993 Alfa Spider Veloce
Uaglio is offline Reply With Quote Quote
Old 13-04-2019   #3
Re: Tyre help
Uaglio is absolutely correct. If you are using original wheels you must use a tube in your tyre. A modern wheel has a 'lip' built into it which holds the bead of a tubeless tyre in place---the original Fiat 500 wheels do not have that 'lip', hence the requirement of the tube. The original tyre size was:--125 x 12, but you can safely go up to 135 x 12, which puts just a little more rubber on the road, and VERY slightly increase your final-drive ratio--engine will turn slightly slower for the same speed, but watch for a slight difference in speed accuracy.
Likes Johngray, lazylobster, fiat500, Uaglio liked this post
the hobbler is offline Reply With Quote Quote
Old 14-04-2019   #4
Re: Tyre help
Help again , what’s the missing number I am being asked for
125/R12/62S or 125/R12/80S thanks again
Old 15-04-2019   #5
Re: Tyre help
Any help please
Old 15-04-2019   #6
Re: Tyre help
According to "Axel Gerstl" (who has the tyres in stock)--it is a:--125 x 12/62S
Thread Tools
(T) Substitute for Fiat Palio Tyre : 165/80-R13 Tube+Tyre Navin Talati Palio 7 18-07-2018 23:00
(T) Tyre losing pressure but no issue with tyre / valve austenw90 Punto (2012+) 7 25-10-2014 16:10
(T) uneven tyre wear on one tyre port3r1987 Grande Punto 0 31-03-2010 17:13
Recommend a cheap tyre fitted by a tyre chain? Chas Uno Leisure Lounge 8 30-03-2007 09:48
(G) Tyre pressure for spare tyre Cinquelover Cinquecento / Seicento 2 19-02-2006 22:02
