Hi Pam, If the car ran OK till it got hot I would point my finger at a, points, condenser or coil (not unknown for coils, especially new ones, breaking down under heat), b, fuel prevaporising, which usually causes problems with poor starting after stopping for a while when hot, c, ignition timing incorrect, or d, valve clearances incorrect, the lack of spring base cups unlikely to cause this problem their main reason for existence is to protect the alloy head from wear. This is all in my opinion. Incidentally are you sure the cups are missing? their presence is often not clearly obvious.
