the hobbler
Distinguished member
- Jul 25, 2012
- 4,084
- 1,013
Ian, did your "air-flow splitter" come with the fan housing or did you have to get it separately? I will have to obtain one, or make one!
The 'Bambino' two piece fan housing is from a German model 126 and I believe fitted against the late square 126 cylinder head......................................
Been after one of those setups if you see another....
Think I may join the "Modding" group...
Ohh I do keep an eye on ebay..,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Regarding the fan housing, I was lucky that it came with a load of bits. I would think that the European (German mainly) shops could obtain one for you, otherwise keep a sharp eye on Ebay
Ian.
I believe they were a German 126 only part....
It is “Gebläsekasten Eckkopf”
The shops say just keep an eye on what we have...
The main problem with this style of stud extractor is that it completely buggers up the thread making it totally unuseable in the future (should it be required) What might be a better option is the stud remover that 'Machine Mart' sells. I believe that it uses vertical pins to hold on to the stud. I have used it very successfully for removing head studs on engines ranging from Lamborghini V12 to Fiat 500. The Part number is:--040213986 It costs about £24 inc VAT.
As others have said, please be careful about supporting the casing to avoid causing any damage.
Al.
Well, knowing my luck I'll bugger up the casing.................. So I'm going to investigate the differing rear mount on the later 500 (Anyone got a schematic of the late mount parts and crossmember) ???? and if that seems beyond reason I'll fall back on an earlier timing casing and pump Some things are never easy :bang::bang::bang:
Ian.
Ian, I have a spare engine with a 126 mounting complete, which I removed today to show you the setup. As an aside, I then had a go at the studs you're struggling with because they will eventually need to be removed for the same reason. The engine has been lying around for years so a good test. I can assure you that despite initially giving you the feeling they won't move, by doing it as Dave described and using a length of pipe over the spanner to avoid suddenly jarring the stud, it moved without drama...in fact they both came out easily.
