Technical Push rod tube seals, silicon or rubber? what size?
gordinir8
Established member
Athens
I have seen that there are two types of tube seals, Do you think i should go for rubber or silicon? Also there are to sizes, small and large, which one is for the 500cc engine?:confused:
Personally, I would go for the silicon seals. If you are fitting new push-rod tubes, you should be able to use the thinner seals as the tubes will not have been compressed shorter. If you are re-using your original tubes, I would be tempted to use the thicker seals as your push-rod tubes, having been used, and therefore compressed, will not have extended back to their 'as new' length.
vdlaan says i should order the thin/small ones, thick seals look also smaller in diameter so i wonder if they are for older type like N or D
And i will use the old tubes
Have you considered the adjustable tubes the VW tuners use. I have them fitted - and have three spare.......a recognized upgrade....
I am aware of those but not for this engine, this is a temporary head only recondition until i find a 650 engine. i don't want to spend money on this one.
i will consider all this add on parts when i will overhaul/upgrade my 650.
Thank you for mention it anyway.(y)
Another option (when you do your 650 engine) is the spring-loaded push-rod tubes---and the beauty of them is that you can just compress them enough that you can fit them AFTER you have fitted the cylinder head--no more fafing around trying to get all the tubes aligned (and the seals sitting properly) as you try to drop the head back on.
Andrew---did you have to modify the VW tubes prior to fitting? I found them slightly too long for the 3-port head, and the Panda30 head has to have the push-rod tube holes in the head opened up slightly to allow the VW tube to pass through.
Im unaware of modifying these VW tubes- they were installed by my engine builder - sorry
Well i ordered both types silicon ones and see what will fit better.
Thank you for your advice guys
Thomas
